Question about Kitchen Appliances - Others
HOW DOES THE LID OF A AEG PRESSURE COOKER GO TOGETHER
OURS FELL APART AND WILL NOW NOT SEAL IT IS ABOUT 4 MONTHS OLD
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
  • 22 Answers
SOURCE: lid of Russell Hobbs pressure cooker is broken
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Posted on Dec 22, 2008
SOURCE: sealer for pressure cooker
I have extra sealing rings.
rmr5758@aol.com
Posted on Apr 23, 2009
  • 8 Answers
SOURCE: I need the assembly instruction for the grow to
http://service.mattel.com/us/product_detail.asp?id=J5970&Ntt=J5970&Pn=1&Brand=Fisher-Price+Seasonal+Sports&Cat=Grow+To+Pro
Downloadable PDF at Fisher Price's website.
Posted on Jun 13, 2009
SOURCE: Rubber seal,+ cushion plug for old model 16 Namco Pressure Cooker
spare parts available from an exclusive namco website in australia, west coast.
Posted on Aug 15, 2009
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
I am looking for a replacement lid for Rival slow cooker SCE502
I believe the design of the handle on the SCE502 is poor and will fail over time. The nut in ours fell out of the handle, and we were holding the black plastic handle while the glass lid was falling to the floor. Ours failed this weekend, and luckily, when the lid fell, it did not break. After looking over the lid and the black handle, I purchased a 1/4-28 screw and a 1/4-28 nut (original was corroded). I drilled a hole completely through the handle and now the black handle is securely attached to the glass lid with a stainless steel screw and nut..
Aug 23, 2010 | Rival 3755 5.5-Quart
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
I can not open my pressure cooker,the lock is still on and all of the steam is out. What can I do to get it open?
Problem is probably that the rubber seal is old and swollen. It will probably take brute force to open the lid. What is the brand name of the cooker? If it's an old Presto or Mirro, it probably has two handles, upper and lower. You may need a person with more strength to force it open.
Once you have it open, do NOT reuse this seal. New ones can be ordered on line at various sites. Do a search on "Pressure Cooker repair parts".
Nov 24, 2009 | Manttra 8QT Stainless Steel Pressure...
Need a new rubber seal for the lid of my pressure cooker 6qt
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Nov 10, 2009 | Wolfgang Puck Electric Pressure Cooker...
Aug 15, 2009 | Crock Pots & Slow Cookers
Cook's Essentials PRESSURE COOKER
I have a cook's essentials pressurer cooker 5 or 6 quart and I have lost the instructions on how to work the pressurer cooker........can anyone help me with the instructions............
Connie
Dec 27, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
35 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
