Question about Canon Pixma MP500 All-In-One InkJet Printer
PRINTER Keeps Printing blank pages and even though new cartridges were installed. What should be done to fix it? Thanks
  • 53 Answers
Pls reinstall the driver
Posted on Jul 24, 2013
SOURCE: Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
Posted on May 27, 2009
prerit_777
  • 214 Answers
SOURCE: My printer is not printing..page comes out blank.
u need to refill ur printer
Posted on Sep 04, 2009
luciana44
  • 292 Answers
SOURCE: Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Posted on Oct 04, 2009
  • 5 Answers
SOURCE: my printer has stopped printing from the cyan ink
Hi, did you let the ink cartridge dry out completely before inserting a new cyan cartridge???
If this is the case you may have a bit of trouble getting the ink through the printhead...you have to persevere with deep cleaning and/or head cleaning...
if that does not work you may need a new printhead...which is usually dearer than a new printer...
I would also take the printhead out and clean the contacts with Isopropol alcohol...do not get finger prints on the contacts...that will stop it very quickly...
just a thought...did you remove the sealing tape over the airholes and bottom feeder hole on the cartridge???
if the airholes are sealed the cartridge pulls a vacuum and the ink will not flow...
hope this helps you...
cheers
haitchhcee
Posted on Dec 09, 2009
herbalgarden
  • 344 Answers
SOURCE: Hi,I am experiencing nothing printing on paper
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Posted on Dec 19, 2009
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
The printer wont recognise the ink cartridge (small black) it is printing a blank page and shows the ink as empty even though it is new and full
II had this and what i can suggest is take the cartridge to where u bought it and have it replaced!The chip on the cartridge might be faulty!Good Luck!
Apr 17, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
C4180 keeps printing blank pages
Try to print a test page using the controls on the printer. This is to determine whether the defects is on your computer or on your printer.
May 12, 2009 | Office Equipment & Supplies
LEXMARK 125 PRINTS BLANK PAGES
have you when into printer properties and done maintence such as "clean cartriges".  If so, it may be possible the ink cartidges are bad.
Mar 01, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark printer printing blank pages
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
abhinav
Jan 10, 2009 | Lexmark Office Equipment & Supplies
Communicates with XP-PC, makes all the moves and sounds- nothing prints
Hi, Hope this helps
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
Jul 21, 2008 | Dell A940 All-In-One InkJet Printer
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
Mar 25, 2008 | Lexmark X1195 All-In-One Printer
The problem is may be scanner assembly of the printer or tonner sensor check this peripheral if possible.
Mar 01, 2008 | Brother HL-2040 Laser Printer
HP Officejet 6210 printing blank pages
Hi steve well I suggest that you remove the cartridges and clean the little gold contacts on the carriage and the cartridge. If this doesn't work then install brand new original cartridges as the cartridegs that you have refilled the data ribbon may have been damaged when you refilled them..
Try the above and I hope it works for you
Thanks J
Oct 23, 2007 | HP LaserJet 4 plus Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
22 people viewed this question
old marine
old marine
