Question about Garden
Instructions for pressure washer try330pwa
Pressure washer plugged in -- no response
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
Spark plug is fine but it doesn't fire when you pull the cord. Water hose is connected and turned on, pressure nozzle open per instructions.
did you check for spark,maybe a new spark plug but check for the spark. if not check coil or wire and boot
Sep 12, 2010 | Honda Pressure Washer PSI 3000
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from www.midwestapplianceparts.com
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Hi I just bought a Honda pressure washer. The
You just bought it which means it is under warranty. Take it back where you bought it or call Honda. You must have the vent plug installed to use the machine. If it is blowing oil out the vent plug then it is either overfull or it is building up pressure for some reason. Make sure it is not overfull and if not, then call Honda and avail yourself of the warranty. If it is overfull, remove enough oil to get it to the proper level.
Apr 16, 2010 | Honda Maxus Pressure Washer MX5222
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Won't start, small engine guy said carburator needed to be flushe
Hi lackeyapda:
Fire Air Fuel
Remove the spark plug, plug it back into its wire. Hold it close to the metal frame WITH INSULATED PLIERS. Pull the cord and see if you get a spark. If no it is the coil, plug wire or a safety switch. If yes
put it back together. Take the air filter off. Spray some "easy start" or "carb cleaner " into the carburetor. Try starting. If it starts for a moment then dies, you do need to clean your carb.
Jun 30, 2009 | Honda Karcher G2400HH-R Pressure Washer
Pressure causes pressure washer to shut off
The engine requires more fuel at higher loads. If unit sat up for some time the jets in carbureator may have become partially plugged due to varnishing. If this is the case, the easiest fix, is to add 'Sea Foam' fuel system cleaner to gas tank. engine may have to run several minutes for this to work. I reccomend tripling the dosage amount reccomended on the label. This should also resolve the problem if fuel starvation is caused by 'sticking needle and seat' problems. If engine stalls with an abrubt clunk, then unloader problems may be responsible. I unit sat up for a long-long time, you may be better off removing the carbureator and rebuild it or have it rebuilt professionally.
May 10, 2009 | Briggs & Stratton Pressure Washer Storage...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
