Air conditioner has red flashing light what causes it how do I turn off
    Master:
  • 435 Answers
2 things due to which this can be happening. Low Gas or Condensation on the machine. Hope this helps :)
Posted on Jul 24, 2013
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
kaycee71
  • 37 Answers
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Posted on Aug 28, 2009
co7196
  • 3433 Answers
SOURCE: Samsung Air Conditioner will not turn back on after power Outage
Turn off the circuit breaker and wait 10 mins, then back on.
Turn off all units, wait a about 1/2 hr. See what that does. Also, Turn only one unit on at a time and let it run 5 min before turning on the secon and the same withe third. An what remote island might that be? Good Luck, Ned
Posted on Nov 11, 2009
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
  • 4736 Answers
SOURCE: My unit is flashing a
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
Posted on Sep 09, 2011
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Furnace comes on but wont stay running,when it shuts off a red light flashes
What light is flashing Red? Is it on your thermostat or is it a red light inside the package unit at a circuit board?
Oct 08, 2013 | Intertherm P3RA-048K Air Conditioner
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
The heat pump and fan stoped working the thermastat red light is flashing a code 2 blower fan and emergency heat working in the house.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Mar 20, 2011 | Heating & Cooling
My air conditioning unit will not turn on... the model is AR-SY1 and flashes with a red light on the timer button?
The lights on the front panel will flash in a certain order depending on the fault. Please count the number of flashes & let us know.
Aug 13, 2010 | Fujitsu 24R1 Air Conditioner
Red light on dash for air conditioner flashers and turn of air conditioner light keeps flashing toyota camry altise 2002
never seen a red light on a dash for a air conditioner before,are you sure its not for the air bag?
Oct 18, 2009 | 2002 Toyota Camry
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
A/c wont turn on, flashes red light.
I have the same warning light (and beeping) on my M6P09D2A. However, I could not get any water to come out of the drain tube. How did you get the water out??
May 29, 2007 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
