Question about Radio Flyer Steer and Stroll Deluxe Trike
Replace parts Need to replace the collar that holds the gears in place. mzrhett@yahoo.com
Noise when shifting gears
transmission synchronizers most common cause of transmisson noise in certain gears, and not others, might want to check the gear oil level. Transmission rebuild required. To read about them and what they actually do, then here is a good read:
When you shift gears in your standard shift car, you move a rod that moves a fork that engages the gear. Depending which gear you're shifting to, a different fork does the job. The fork moves the collar to the desired gear, and dog teeth on the collar mesh up with holes on the gear in order to engage it. You engage reverse gear through a separate, small idler gear. The reverse gear always turns in the opposite direction of the other (forward) gears.
In years past, double-clutching was common in order to disengage a gear, allow the collar and next gear to reach the same speed, and then to engage the new gear. To double-clutch shift, you pushed the clutch pedal to free the engine from the transmission. Then the collar moved into neutral. You released the clutch and revved the engine to get it to the right rpm value for the next gear so the collar and the next gear spun at the same rate to allow the dog teeth to engage the gear. When the engine hit the right speed, you depressed the clutch again in order to lock the collar into place on the next gear.
Modern cars use synchronizers in order to avoid the need for double-clutching. A synchronizer, or "synchro," lets the collar and gear synchronize their speeds while they're already in contact but before the dog teeth engage. Each manufacturer's synchro is slightly different than the others, but the basic idea is the same. For instance, a cone on one gear will fit into a cone-shaped depression on the collar. The gear and collar synchronize their speeds thanks to the friction between the cone and collar. Then the outer part of the collar moves out of the way so that the gear can be engaged by the dog teeth.
Dec 16, 2013 | Chevrolet Silverado 2500HD Cars & Trucks
The black, round "collar that holds the headlight
The part you are referring to is the headlight socket. The link below will take you the part in question. This is what to look for. Most auto parts stores should carry this part.
2001 Villager Headlight Socket
Aug 12, 2011 | 2001 Mercury Villager
2009 Yamaha yZ250 4th gear keeps getting hot and galling
Hi, Msportum5618 and I have been told, read, ridden, and believe the Yamaha YZ250 is an ICON and one of the greatest dirt bikes ever made. Any bike is subject to failure, especially competitive performance machines. The oil type is not the issue the usual suspects are:
1. Incorrect transmission oil level.
2. The oil delivery system to the shaft is malfunctioning.
3. The shaft is bent, runout should be 0.002" max bearing/running surface damaged/galled or has lost its hardness due to excessive heat/blue color and gear failure, a new replacement recommended.
For this scenario, you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2008 YZ250 not shifting
2009 YZ 250 lost 4th gear
YAMAHA YZ250F Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jun 06, 2017 | 2009 Yamaha yZ250
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
How to remove the cutters on model ksb560mco pctag@verizon.net
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
Dec 31, 2010 | KitchenAid KSB560 5 Speed Blender
Change a tap washer
Turn off water at wall valve under sink. Turn on tap to ensure valve is shut off. Remove tap handle. Remove cap, collar or bushing holding shaft in place. Shaft may need to screwed out to remove. Replace washer on end of shaft, then re-install parts in reverse order.
Nov 10, 2010 | Home
My primer button as broken how to replace it and where to buy the
Lowes Home Improvement store carries them, also lawnmower repair stores have parts departments that have them. Mine cost about seven dollars.
Apr 19, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
How to reassemble header for 2002 Kawasaki Ninja 250
first lay out all your exhaust system parts . take inventory.2 ex. gskt.2 mffler gskt,left muffler(short),right muffler(long), header pipe,4 collars, 4 nuts(6 mm),2 holders,2 muffler clamp,2 hanger bolt,2 nut( 10 mm). next. put small dab of grease on exhaust donut gaskets so they will stay in place by themselves when you stick them in place in the exhaust ports ,on the cyl. head.next gather collars, head pipe w/ holders & 6mm nuts, w / 10mm .wrench or socket.tricky part,hold head pipe up in plce to head,take collars w/ lip or bend facing out & put in between pipe holders & ex. donut gaskets,place holders over exhaust studs & install 6 mm nuts & tighten evenly but do not tighten all the way just keeping collars in place. now hang mufflers,w/ gaskets,clamps,nuts, & bolts,loosely.now tghten down head pipe evenly,cheking collars for proper alignment as you tighten.next,tighten mufflers to headpipe w/ clamps using 12 mm socket or wrench.next, tighten mufflers to frame using 14 mm.finally, start bike & check for exhaust leaks.
Feb 14, 2009 | kawasaki Ninja 250R Motorcycles
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Does not eject sheet
In the scanner unit there are 2 sets of ejection rollers. The first set (one farthest from you) there is a gear on the left hand side the probably has a worn collar on it that needs to be replaced. There is a black tab that sits in a slot on the right side of the shaft that holds the shaft in place. GENTLY move the tab away from the shaft then move the shaft to the left. The white gear on the left is the one that needs to be replaced if the collar is not perfectly square. Part #LE1196001. Hope that's it. Ed
May 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Radio Flyer Steer and Stroll Deluxe Trike Logo
177 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
obsteiner
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
