Question about Wilkerson Consolidation Filter Regulator C04-02-l00 Air
Worn O-ring in bottom of bowl
Hello, I have this regulator integrated into a larger manafacturing machine so replacement is more involved. What I need is the small black O-ring at the bottom of the bowl. It has worn out and is allowing air to leak. Is this O-ring available?
Fisher & Paykel washer spins without clothes but not with clothes in it?
That could be two problems:
First: Suspension rod\s has popped out or has gone bad.
Second: "Bowl" Top or bottom ballast ring has lost ballast water.
Bowl needs replacing.
Jun 07, 2017 | Fisher Washing Machines
Why does my keihin carburater leak gas from a hole in the bottom
Hi, 315 and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 31, 2017 | Winter Sports
What is the sizes on new & worn rings on Bajaj RE205 Piston
the size of the ring will be determined by the bore size
so if it is a 3"(75mm) bore the ring will be that size if placed in the bore separate to the piston and pushed square and to the bottom of the bore the ring gap will denote if standard , worn or oversize to standard
new rings in new bores will have a ring gap of around .010"
worn rings will have a larger gap up to .040" and will have sharp edges where the ring lands wear the rings
over size rings in standard bore probably won't even fit in the bore to start with
ring sets are bought in standard size , .010" over size,.020" oversize,.030" oversize,.040" oversize with the oversize equalling the final hone of a machine bore
so if the machine shop bores the cylinder out to .020" oversize then you need .020" oversize rings to maintain the correct ring gap
from experience I have found that if I follow that rule , on measuring the ring gap at the bottom of the bore the ring gap is about .015" or half worn out
I counter this by getting the next size ring .030" and filing the ends of the rings at the gap to obtain the .010" gap This has produced better longer lasting repairs
Jul 27, 2015 | Bajaj Motorcycles
Fuel leaks out over flow of cv carb on dyna tank
Hi Anonymous, and the usual suspects are:
4. Improper fuel level in float bowl.
6. Damaged or leaky float assembly.
8. Ethanol sludge, dirt, rust in bottom of fuel tank
Good luck
Jan 27, 2013 | Harley Davidson FXD Dyna Super Glide...
How to fix my fisher & paykel washer machine from shaking and knocking
Your 4 suspension rods will need replacing as they are loose & worn.
Or the bowl has lost its ballast water from the top & bottom balance rings of the bowl.
Jan 05, 2013 | Fisher Paykel WA42T26GW1 EcoSmart 25" Top...
1995 harley sportster leaking fuel from carb
Good luck
Aug 01, 2012 | 2003 Harley Davidson XL 1200 C Sportster...
Keeps getting out of balance
It could be one of two things.
1.Suspension damper rods need replacing or
2.The bowl has lost its ballast water to balance the load
The bowl has two ballast rings top and bottom
with some water in them.
If this water is gone from the rings the bowl will go out of balance all the time.Replace the bowl if this is the case.
Jul 30, 2012 | Fisher and Paykel Washing Machines
Replace rubber on dog dish
I had the same problem and will be making the replacement rubber rings for pet food dishes - available in approx. 2 months. I will be offering replacement rings for 6" diameter steel bowls at first, but will move into the larger sizes soon thereafter.
Please contact me for details! azkateo@gmail.com
Jun 26, 2012 | Proselect X-Super Heavyweight Non-Tip Pet...
One side of my bunn ultra 2 slushie machine is leaking how do you change a bad seal to stop this problem?
remove the bowls by pushing in black button on the bottom front left of the bowl, pull the bowl up a little, then pull it forward and off. pull the auger off and the seal is opaque, cup shaped, and on the shaft. replace that, lube the edge with food safe lubricant (i.e. superlube), lube the large round bowl seal in the back and put it all back together. you may need a preventive maintenance kit installed as well, but that's a bit more involved
Sep 28, 2011 | Bunn Margarita Machine Ultra 2 Slush...
I have a Miele CVA615. I think I should replace
Hello Phickok,
It sounds like the perculator may need to be replaced (The entire unit with the 'O' rings on it). As I recall the plunger is an integrated piece that cannot be replaced on the CVA-615/620 models but you may want to contact Miele technical services on this. These first generation coffee systems are very complecated to troubleshoot
Sep 05, 2009 | Miele CVA615 Espresso Machine
Wilkerson Consolidation Filter Regulator C04-02-l00 Air Logo
44 people viewed this question
Top Wilkerson Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Wilkerson Air Tool and Compressor Expert? Answer questions, earn points and help others
