Question about Burndy PENA4: Electrical Joint Compounds
Will this product be okay for a bare copper to nickel plated bus bar joint?
Which is the leading company of manufacturers of copper bus bars?
One of the leading manufacturers of copper busbars in India and has been so over the last three decades. Copper busbars manufactured by our company are available in both high conductivity OFC (Oxygen Free Copper) and ETP (Electrolytic Tough Pitch) grade. Leading Copper Bus-Bas Manufacturers in India
Feb 22, 2017 | The Computers & Internet
Name The Best copper wire manufacturers in India?
We are the largest companies producing copper wire manufacturers in India.The Company deals in Copper products such as Copper Rod, Strips, Pipes, Busbars, Sheets among others and has been a partner to its clients who are primarily Original Equipment Manufacturer (OEM). Over the years the organization has diversified into Telecom products, Solar products, and Real Estate.
Feb 22, 2017 | Best Computers & Internet
I require a method for the useage
Kemtex B916 solder paste?
This = No
"Kemtex B916 Tinning Compound
A 40/60 grade solder paste suitable for sweating together fine tolerance joints and in areas where conventional hand soldering is hard to apply. Also used for tinning motor car bodies prior to the application of bodyfill solder. Can be used for tinning bearing shells for lead based bearing metals."
http://www.cagroup.com.au/Kemtex_Fluxes_and_Tinning_Compounds.asp
Should state Rosin Flux Paste for what you want.
I'll bet the above is acid based.
http://www.radioshack.com/product/index.jsp?productId=2049774
Regards,
joecoolvette
Mar 04, 2013 | Computers & Internet
Does nickel rust
No, only ferrous metals like iron and steel rust.Nickels are made of 75% copper and 25% nickel, and copper can oxidize to form a green patina (not called rust, ......It is very resistant to corrosion. nickle is used in many different places, because of its ability to resist corrosion. Like most metals, nickel can rust when exposed to excessive water or moisture for long time periods. good-day !
Feb 23, 2012 | Home
Just installing the 200 amp panel and would like to know where the bare copper ground is supposed to hook up? Is it on the opposite end of the neutral bus?
All neutrals and all ground wires connect to the neutral bus. Where you connect them on that bus is simply a matter of being tidy and leaving room for future work. Of course your physical ground (the one going to the copper rod pounded into the earth) must be connected to this bar too.
Jan 27, 2011 | Siemens 200 Amp Main Breaker 30 Spaces 40...
I am making jewelry with the iron....my tips are dispersing...what is my problem. Should I use a different watt. All that I am doing is soldering over copper foil to broken china.
25 watts is a pretty light iron for the kind of work you are doing, but if it works---. Tips that are just bare copper tend to erode over time (the heat causes the copper to mix with the solder and thus erode). The better tips have iron plating over the copper which protects the copper. Silver solder applied over the bare copper works in much the same way and can be applied with a propane torch. Hope this helps!
Oct 25, 2010 | Weller 25 Watt Soldering Gun Kit
Replacing Tip Weller SP40L
It just corrosion. Take a pair of slip-joint or grip pliers and twist the tip back and forth until it release.
If necessary use PB Blaster® or WD-40® for the corrosion.
MT10 1/4"/10mm diameter replaceable nickel-plated copper tip
Mar 24, 2009 | Weller Marksman Iron 40 Watt SP40L
Residential Electrical Wiring Current NEC
On a 120/240Volt single phase system is:
Black = 1st phase
Red = 2nd phase
White = neutral
Green or Bare = ground
3 phase is the same with the third phase being blue.
Jul 28, 2008 | Motorola 3-Wire Surveillance Headset...
Burndy PENA4: Electrical Joint Compounds Logo
616 people viewed this question
Top Burndy Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
Are you a Burndy Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
