Question about Karcher Garden
Oil in air filter
I have a karcher 2300 pressure washer. During use it started smoking so i shut it down and found the air filter and its compartment soaked with oil.
To much oil.
Posted on Jul 25, 2013
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 174 Answers
SOURCE: My 2200 Gc Karcher pressure washer oil got mixed
If you are talking about the oil in the pump then it should be 10W30 but must be NON DETERGENT. Remember the reservoir should only be 1/3 full
Posted on Aug 09, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
Karcher pressure washer smoking any ideas
is the crankcase over filled? To much oil will cause that, and check the air filter. I had a motor that sucked air thru the crankcase breather (and the oil with it) when the air filter was plugged up.
The only other cause I can think of would be a bad or broken piston ring.
Aug 20, 2014 | Garden
The pressure washer started smoking and shut off now it won't start
check for possible excessive fuel and or oil in intake by removing air filter and looking in the throat of carburetor.
Aug 03, 2013 | Karcher G3025OH Pressure Washer
Overfilled the oil and black smoke came. Can't startt now what i need to do
hi there pauly46 here
remove plug, pull engine over to remove oil from combustion chamber , clean plug,
refit, remove air filter - replace it if its wet with oil / or water damaged and clean backing plate , drain float bowl and check oil in carb, refit bowl and connect water supply to pump - turn on and start engine ( sounds like you hydraulicd the piston in the cylinder )
engine may blow blue / white smoke for a while then settle back
note do not use a sae 30 , use a 20w/50 oil or 10w/40. honda engine with low oil shut down
units on them have a problem with sae 30 oil
cheers hope it helps
pauly46
May 13, 2011 | Karcher 2500 PSI Pressure Washer
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Engine runs rough, burns tons of oil, and keps shutting down
Could be too much oil. Check oil livel and make sure that the oil is not too thin (gasoline in oil). Install new spark plug, add premium fuel in tank and start engine without the air filter (air filter could be dirty or soaked in oil). Run for a while to see if condition improves (no or less smoking). Replace air filter while the engine is running to see if it makes a difference in performance. If installing air filter had no effect, and engine continues to smoke most likely valve guides or rings are faulty. Hopefully it will clear up. Good luck
Nov 07, 2010 | Briggs & Stratton Garden
I borrowed my nieghbors power washer. It worked the first day all day. In the morning i filled the gas with a fuel stabiler, and 30 oil. I may have over filled it. Upon turning it on the oil started...
You will need to get a new filter, and drain some of the oil out of the machine. If you over fill these this will happen. 90% of the time nothing is broken.
May 23, 2010 | Karcher 2500 PSI Pressure Washer
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
70 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
