Question about Mitsubishi WD-73737 73 in. HD-Ready TV
Wont turn on
It turned off by itself one day and hasn't came back on since. The power light doesn't even come on. What would the problem be?
    Top Expert:
  • Mitsubishi Master
  • 74,106 Answers
There are so many reasons for this fault. It will be best to contact any service technician.
Posted on Jul 24, 2013
My htc 8s wont charge
Do not do a hard reset,you don't need to. Hold the power button down for twenty seconds and the phone will reboot itself.
Jun 13, 2013 | HTC Windows Phone 8S
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Wii not turning on?
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 29, 2012 | Nintendo Wii Console
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
Will turn over but wont start cant hear the fuel pump
If it hasn't run in a couple years, I would use a "test light" and check for power at the plug-in for the fuel pump. If ther's no power I would run a wire from the battery straight to the fuel pump itself. If the pump doesn't turn on you will have to replace the pump. If this starts it. If this makes it work you could put a fuse in the wire and hook it under the hood to any wire that has power when you turn on the key.
If you are trying to get it running again after 2 years it might be a good idea to pick up a Haynes manual for the car. They're only about $20 and have a lot of useful help for the DIYer doing average repairs. Hope this helps.
Nov 12, 2011 | 1990 Subaru Legacy
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Jun 26, 2011 | 1999 Chevrolet Venture
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to...
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
May 20, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Gateway 825gm wont tun on. just replaced on/off switch. greem light on power supply and mother board blinking green
Make sure the small cable from the switch to the mother board hasn't come loose. It comes loose fairly easily when reinstalling the cooling fan plenum. Its happened to me twice. Its even possible to plug it in the wrong place. Doesn't hurt to double check.
Dec 24, 2010 | Gateway 825GM PC Desktop
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
