Question about HP Pavilion zd8000 Notebook
Cd rom problem
My cd rom is not picking up cd's. checked it oput and it says i have a error code 41. can you help???
  • 63 Answers
Http://www.techgalaxy.net/Docs/WinXP/XP_error_codes.htm This problem tells you that windows has loacted the device driver but cannot find the hardware device. I would try going to HP website and letting it "autodetect" your PC. See if there is an updated driver for YOUR device. You just may have the wrong driver installed for the device. Opening a laptop is a pain, so I would take it somewhere and make sure the connections are good on the inside. If none of this works, your device is in need of replacement.
Posted on Aug 30, 2007
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. I cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk. To resolve this behavior, follow these steps: Start Registry Editor (Regedt32.exe). Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} On the Edit menu, click Delete, and then click OK. Locate the LowerFilters value under the same key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} On the Edit menu, click Delete, and then click OK. Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance. Restart your computer.
My computer list the cd-rom but have exclamation points by both units. the error code 41
Hello
A yellow circle with a black explamation point indicated that the device is not funcioning correctly. This is usually resolved by upgrading the firmware/drivers for the device. I went on samsung.com and found the latest for your CD-RW drive and have included the link below.
Please click Firmware in blue on the page and then download the latest. It is reccomended you create a system restore point prior to installing in the unlikely case that the install causes system instability.
http://www.samsung.com/us/support/downloads/SM-348B
If that happens you can press F8 as windows boots and select boot into Safe Mode. Then go to control panel, system, device manager, select the device, properties, driver, and hit roll back driver.
Hope this helps Please vote if so :) Have a great day
Jan 26, 2011 | Samsung SM 348B CD-RW/DVD-ROM Combo Drive
Code 41 error
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 17, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My tsstcorp cdw/dvd TS-H492C rom is not being displayed on my comp....it displays a message... Dat is windows successfully loaded the device driver for this hardware but cannot find the hardware device....
Hi
I see this is a month old,but I'll answer this for anyone doing a future search that may come across this thread.
The link is to Microsoft's on-line repair center.This will fix several error codes,including 41,and is probably the first thing to try when your optical drive is installed but Windows can't find it.
If this helps with your problem,and anyone in the future,would you rate my post please?
Thanks
Bob
http://support.microsoft.com/gp/cd_dvd_drive_problems
Jul 12, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Computer cannot find CD ROM drive (code 41). It was working yesterday and I haven't changed or moved anything.
http://www.dougknox.com/
Select 'Windows Utilities' and scroll down to 'Restore CD/DVD drives to
Windows Explorer.'
found this, maybe it'll help?
May 12, 2010 | HP Pavilion a1450n PC Desktop
DVD/CD Rom Drive - Cannot find hardware devide
i think you have the motherboard to rom drive cable problem, plz change your cable and try again....
Nov 11, 2009 | E-Machines eMachines Desktop PC
I have a 94 dodge caravan it idles fine but it is running rough engine codes I picked up are 12 and 41 and 55 do you know what these codes are. Thank You
12-direct battery input to PCM was disconnected within the last 50 key-on cycles
41-generator field not switching properly
55-end of error messages
Check sparg plugs, ignition cables, fuel system (fuel filter, injectors)
Oct 31, 2009 | 1994 Dodge Caravan
Dvd and cd rom code 41 erreor
The driver is corrupt, un and reinstall it. To uninstall go to control panel and then add/remove programs.
Oct 20, 2009 | Dell Computers & Internet
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
HP Pavilion zd8000 Notebook Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
