Acer ah002s light is on,shows in toolbar but not on my computer.
Acer ah002s cant dettected
Have you tried the harddisk on another computer to make sure it is functional? It can also be related to one of the following things:
1. If the harddisk is formatted for MAC and you use windows it might not show up unless you install special software.
2. The USB outlet on the computer might be faulty (try another one).
3. The cable might not work. In time they can break inside without any exterior signs.
4. Are you sure the harddisk is receiving power or is it supposed to get that through the USB cable? If it is, then the voltage in the USB on the computer, might not be high enough. Then check if there is an USB with yellow interior. That will have more juice than the rest.
Sep 07, 2014 | Computers & Internet
Acer ah002s drivers
If this is a second hard drive or it is an external drive, you need to check its status:
[Start], Control Panel, [System and Security], Administrative Tools, Computer Management, Disk Management.
You have to login as an administrator or right click the Computer Management and chose "run as administrator".
Please post the result, so I and other helper can help you if you still need help.
Feb 24, 2014 | Acer Computers & Internet
Words on computer too light
if the words are to small to read
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help
select the view tab from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
hope it helps
Oct 06, 2012 | Acer Computers & Internet
My external drive Acer AH002S is not being detected although the light is on and the disk spins from time to time
I have opened my Acer AH002S External Disk simply with a knife. Put the tip of the knife next to the USB connector, but between the union of the two sides of the box. Press slightly inwards, and the knife enter, releasing the first of the 9 tabs. Without removing the knife, down to the other end of the case gradually, releasing each of the tabs. Repeats the process in each of the three sides of the box. At the end you will have released three of the four sides, and you can remove the disc (in my case a Western Digital 500 GB), which is welded, but a sata connector.
Disk was wrong, and need to replace it.
May 25, 2012 | Acer Computers & Internet
Software witch is normally on the AH002s external hd, ik deleted it can you help on a new copy?
It is pretty much a plug and play device on windows XP, Vista and 7 so there is no need for the drivers or software to use the drive. But if the drivers are useful for any other functions like private folder option you need to contact the Acer support and request for the software as these are not available on their website.
Good Luck!
Jun 14, 2011 | Acer Computers & Internet
No icons or tool bar on desktop at startup
In your desktop, Right click your mouse and properties will show and look for show desktop option. And then move your mouse to the bottom of your computer screen, if toolbar will show, then your toolbar is set to automatic hide. Change the settings in your Taskbar and Start Menu Properties and change there the settings, uncheck the auto hide task bar.
Nov 10, 2009 | Acer LX.W530X.012 Gateway M7325u 15.4in...
Aol screen stopped showing lower toolbar
Enable the AOL Toolbar If the AOL Toolbar is disabled, it will not appear as part of the Internet Explorer toolbar.
To enable the AOL Toolbar in Internet Explorer® 6.0 and earlier:
On the browser window, click the View menu, select Toolbars, then click AOL Toolbar.
To enable the AOL Toolbar in Internet Explorer 7.0:
On the browser window, click the Tools menu on the right side, select Toolbars, then click AOL Toolbar.
To enable the AOL Toolbar in Internet Explorer® 8.0:
Note: When enabled, a check mark will appear next to AOL Toolbar.
Nov 10, 2009 | HP Computers & Internet
I can't access my Gateway Built In Webcam Toolbar
If its vista just press start and type in "camera assistant software"and press it.
Oct 08, 2009 | Gateway M-1626 Notebook
The toolbar has disappeared
Ok, on windows desktop screen right click your mouse, select personalize, click on TASK BAR AND START MENU, pop up will show select TOOLBARs, then check Quicklaunch.
If icon is missing just create short cut to your desktop, then click and drag, then delete shortcut in desktop screen.
This is for vista.
As for XP it should be properties for personalize, then search for the link.
Leave a comment if this is not the exact one.
regards
Apr 25, 2009 | Acer Aspire One A150-1006 Notebook
ACER X193 MONITOR DISPLAY ISSUE
Windows doesn't know your display is broken as it see's your display adapter for the laptop. By adding the monitor windows is adding a second display to the one you don't actually have, your icons and start bar are still on display 1
sorry
Sep 28, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
