Question about Ricoh Office Equipment & Supplies
Startup issues ready does not appear
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
Fired wire, faulty motherboard, can be many reasons.
Posted on Jul 25, 2013
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
Sony vaio ns series notebook windows failed to start. it displays two options; 1. launch startup repair 2. start windows normally. first i click the second option but it didn't work. next i click the...
The issue may appear due to several reasons such as Windows Update or any recent hardware or software changes in the computer.
1. Please reset the BIOS to default values.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C96925
2. Try booting the computer to Windows in safe mode by pressing the F8 key at startup.
3. If the issue persists, please check if the hard drive is listed with its volume (size) eg: 500GB in the BIOS main menu. Press F2 key at startup to enter BIOS.
4. If the hard drive is listed, perform a system recovery using the recovery console/partition by pressing the F10 key at startup.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1013184
5. If issue persists, please use the recovery discs or contact the sony service team to get the computer repaired.
The issue may be related to the operating system files. Getting the recovery partition re-imaged will be the best possible resolution.
May 24, 2011 | Sony VAIO Notebook PC VGN-NS235J/W
On startup, a cloud and black screen appears, which turns out to be green after startup.
Hi, the issue seems to be with the Corrupted Video Driver, Try Uninstalling the Video Driver Completely. Restart the Computer Now first Install the Original Driver using the Recovery Console(OR Recovery Discs) provided by Manufacturer. Later Update the Video Driver to the Latest Version. If that didn't solve the issue, Check for the BIOS update, Update the BIOS. This will resolve the issue.
Nov 23, 2010 | Computers & Internet
Display is not working no details
As you have not mentioned any model of Apple Laptop.Assuming Mac Book Pro 15 " as viewed in the picture.Connect the laptop with external display using DVI to VGA converter and power on the laptop.If the display appears in external monitor,that means the issue is with LCD Panel or may be the LVDS cable is faulty.If stil there is no display in external monitor then the issue is with Logic board. Also check weather the startup chime is appearing or not.If the startup chime is not there, replace the ram with a good one and check.If the issue is with logic board , display or Ram then you have to replace the pirticular par.
Apr 07, 2010 | Apple PowerBook G4 Mac Notebook
I'm getting a hp all in one printer error that I can't cancel out it just keeps repeating
  1. On the Start menu, click Run. A Run window (command prompt) appears.
  2. Type msconfig in the Open field and click OK. The System Configuration Utility opens.
  3. Click the General tab.
  4. Select the "Selective Startup" option.
  6. Click the Startup tab.
  7. Select the "iTunesHelper" and "qttask" checkboxes in the list. 302538_2.jpg
  8. Click the Services tab.
  9. Make sure that "Hide All Microsoft Services" is selected.
    Note: If you are troubleshooting an iPhone related issue, select the "Apple Mobile Device Support" checkbox.
  11. Click OK.
  12. Click Restart.
  13. After restarting (and logging in to Windows), a window appears confirming that "You have used the System Configuration Utility to make changes to the way Windows starts." Click OK. The System Configuration Utility appears. Do not click OK here as this will prompt you to restart again. First try to reproduce the issue you were having.
Mar 31, 2010 | HP Office Equipment & Supplies
Dell d410 laptop has a locked mousepad and when I turn it on.
The led, is indicating that the Numlock is engaged on the keyboard.
If the touchpad stops responding but keyboard inputs work, then the touchpad is either failed or disabled. If the keyboard is none responsive too, then the operating system has locked up and that is an entirely different issue. If the OS is locking up, try booting to SAFE Mode from the F8 menu and see if you can access anything. If still locking in Safe mode, you may end up installing Windows Again. If Safe mode works, then you can check event logs and edit MSCONFIG startup group and the like to find the SW issue
Sep 17, 2009 | Dell Latitude D600 Notebook
I have a 2003 Hyundai Santa Fe V6 3.5L with automatic transmission. 48K miles. When I start the car after sitting over night, I hear this whirring/whining noise from the engine compartment. I goes away...
your whining noise might be comming from dry belts in order to pinpoint your problem have a jug of water ready before startup open the bonnet then startup if the noise appears pour water over the belts if noise goes away replace v belts
Jul 13, 2009 | 2003 Hyundai Santa Fe
Recent issue not solved and ongoing issue with notebook
To disable them from startup
you can go to run type in msconfig a box will appear then click startup you should find them in there remove check from anything you don't want to run on startup.then restart a box will appear check to never show again.
Jan 12, 2009 | Dell Inspiron 1000 Notebook
When download hp photosmart fatel error during installation appears error1935. download stops and starts uninstalling.
if you have any firewalls or virus scanners running please remove them for install purposes only.
you can also go
Start--->Run--->type: msconfig---->in the general go to diagnostic startup---->accept, close and reboot
Install the software it should install now.
Then reboot
then goto
Start--->Run--->msconfig---->in the general options to to normal startup--->accept, close and reboot.
Now your software is ready for testing.
Alot of the HP Software has a issue with firewalls and virus scanners when being installed if that does not work go to the diagnostic startup again and try downloading the setup again if using a disk then chances are its gonna work fine.
Please let me know how you made out.
Aug 02, 2008 | HP Computers & Internet
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
