Question about Vehicle Parts & Accessories
Optra alarm Please.The antitheft system become ,silent How tom amke it work again
2 Suggested Answers
  • 12650 Answers
SOURCE: I have an 05 rendezvous, factory antitheft system is not working, when I push the panic button on the key fob, alarm comes on, but when I reach in the window and open the door, alarm does not work
if door is not locked when u reach in wont activate alarm --try lock dr and use key in lock and open dr alarm should activate in a few seconds and will shut off when key put in ignition or key fob shut off -if it does not set it off --check ur settings thru ur dash information if setting is as you want than may have to have system reflashed at dealer
Posted on Jul 20, 2015
Antitheft system keep goes on so i can't start my vehicle
It is telling me to lock the doors with the key, this will arm the system, then you should be able to unlock the doors after about 3 seconds and this should disarm the system. Also, if it doesn''t try unlocking the passenger side door or the back glass with the key. Let me know you must wait at least 3 seconds before unlocking back glass or passenger door to disarm system once one door is unlocked without setting off alarm it is disabled. hope this helps
Aug 06, 2014 | 1998 Nissan Pathfinder
Hi. i have a problem.I bought a new alarm beret 2 way 5000m and setup on my motorcycle. Alarm is working. Then i did switch to silent mode and now back to normal mode does not. Alarm always work silent...
If the Remote is now working now, the problems in the future will continue and get worse. I would recommend removing it and returning it for a Higher Quality Alarm System
Mar 03, 2014 | Motorcycles
Need a wiring diagram for car alarm PTC-2000 can u find? I cant
hi there I have a remote control vehicle security system PTC-2000
I cant seem to figure the button function out. please can you help me. it works but atm on silent how do I get it out of silent mode. please help thanks
Mar 08, 2013 | Vehicle Parts & Accessories
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
Won't start, could it be fob or engine?
Try not using the fob at all open the door with the key. And start the jeep if it works without issue then its the fob. If its still not working correctly remove the battery from the fob and try again(since if it was damaged could be sending the signal for the panic button) the next step is the key try your spare security key can become worn and cause issues with the antitheft system. After that it only leaves computer problems and those can get spendy
Jan 05, 2012 | 2005 Jeep Grand Cherokee
Car wont start after alarm goes off, how do i first of all make it start and then totally dissasemble the alarm system?
Are you talking about an actual alarm system, or the built in antitheft system? If its the antitheft, which is a common GM problem, this link will help. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 27, 2011 | 1988 Cadillac Sedan DeVille
Car wont start ignishen disabled due to antitheft system
Get the system bypassed by an auto electrition.Then you want have an alarm.Or get a new alarm fitted
Jul 25, 2009 | 1995 Cadillac DeVille
Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Jul 16, 2009 | Vehicle Parts & Accessories
Need to disarm antitheft alrm in my 99 fierbird
You might have a problem with the antitheft system, I don't know what you've done or tested so far. But usually with the alarm enabled there wont be any start at all. It does sound like there is a problem with the ignition switch, but that's only if it starts and stalls after you let the ignition key go. The anti-theft alarm, is this a VTD, factory system, a factory alarm system, or an aftermarket alarm?
Jan 29, 2009 | 1999 Pontiac Firebird
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
