Question about Hardware & Accessories
2 pieces of rope
If you have 2 pieces it takes 60 minutes to burn the rope to the end you cannot bend the rope how do you measure 45 minutes
    New Friend:
Put the two pieces of rope together with one quarter of each rope protruding out at either end. The time that the ropes are both on fire simultaneously will be 45 minutes.
Posted on Jul 30, 2013
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
on Oct 28, 2013 | Sport & Outdoor - Others
Can I repair the broken starter rope on Stihl FS 45 trimmer
If you're pretty handy, you should be able to do this yourself. Once you get the housing off the motor, you may be able to dig the broken end of the rope out of the pulley and wind the spring back up with it, then feed it out the hole. At that point, you could jam the pulley with wooden wedges or something, disconnect the rope from the pulley, and feed in a new rope.
Jul 26, 2014 | Stihl Garden
How to fit new starter cord
remove recoil cut off old rope take new rope burn end till pointy push threw recoil and into hole in pulley tie knot on pully side add handle pull string between pully and outer shell rotate pully counterclockwise 4 times with rope you puled from out in between pull access back out of the housing till tight release or go to a shop they normally only charge ten bucks
Mar 05, 2013 | Makita DPC6410 64cc 12" Power Cutter
Is there a diagram for bypassing the ac compressor pulley and what would the belt length be?
Make you own. Just used a piece of rope. Once it has been measured add a inch or inche and half to the rope. This is to take up the slack for the belt tensionor. Then take your old belt and the new measurements to your local auto parts store and have fit a new belt to the rope measurements. GB...stewbison
Sep 04, 2011 | 2000 Ford Mustang
Pull cord will not retract
The main spring breaks out of the center piece that the rope is wound on. You have to take the broken end of the flat spring out, file a special divit into the spring steel the same as the stock end was (NEVER BEND SPRING STEEL), wire the spring coil at least five places or it will explode in your fingers, and then insert your new end into the center piece with a twisting action. Now pack the spring up into the unit while releasing the five wire ties on your coil with the last action pressing downward with your thumbs so the spring is in there and the rope is wrapped on the center piece - ready to revolve the spring and get more tension as the rope comes out.
I did this in an aluminum boat on a 9.9 Mercury motor in the middle of a Northern lake one time!
Draining old gas before winter storeage helps to reduce endless pull starts which break these springs. A good trick is to take out the spark plug and load it with a squirt of new gas rather than pulling very old gas down the carburator line into your engine which makes you pull the chord forever without results, and break the spring.
Mar 24, 2011 | Garden
How to measure coffee for 45 cups. Also is a filter needed.
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
100-CUP MODEL #33600
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
Mar 09, 2011 | West Bend 33600 Coffee Maker
STARTING ROPE BROKE AND UNABLE TO START MOWER
Hi,,,,replaceing the rope is easy, just takes sometime. first, take the cover off the engine. turn the cover over and rope pully should be right there. Measure out 8 foot of new rope. burn both ends of rope so it don't fray. get all of the old rope off the pully. here is where an extra pair of hands come in handy. by hand rotate the rope pulley 6 revolutions, now have someone hold the pulley, then feed rope thru the cover and thru the pulley rope opening, then tie a knot in that end, now slowly release the rope and it will wind itself onto pulley, now put rope thru the handle and tie knot, now put back togeather and go mow your lawn,,,lol
Sep 22, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to install pull rope on Craftsman 917.37717 lawn mower
First, this is best done with two people, unless you have 4 hands. Second, with rope pull cover off the mower and laying on table with rope pulley up so you can see it, remove all the old rope. Next, measure 8 foot of new rope.
Now, line up the holes where rope will go thru the cover and into pulley, now with someone holding the cover, rotate rope pulley 6 complete turns, now hold pulley there, while putting new rope thru the rope openings in rope pulley and outer cover. Tie knot on end by rope pulley and have who ever was holding cover and other end of rope, slowly release the rope so it rewinds, install rope handle and walla, your done. 5 minute job, depending on how much coffee you drink. Hope this helped you.
May 28, 2010 | Craftsman Garden
Hardware & Accessories Logo
32 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
