Question about Yamaha RX-Z11 11.2 Channels Receiver
HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
    Genius:
  • Yamaha Master
  • 1,054 Answers
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Posted on Jul 24, 2013
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
smarthome2
  • 1114 Answers
SOURCE: I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Posted on Aug 13, 2009
SOURCE: We have a Yamaha rx-v365 AV receiver. In basic
i have the same problem. any answers? navychief872000@yahoo.com
Posted on Nov 24, 2009
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Jan 06, 2017 | Yamaha Audio Players & Recorders
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
Impedance setting on Yamaha AV Receiver
Hi. You can always use a Receiver with an output impedance that is lower than the speakers input impedance.Problems arise when you try to use a Receiver with a higher output impedance than the Speakers input impedance.
Receiver 6 ohms speakers 8 ohms......YES..
Receiver 8 ohms Speakers 6 ohms.......YES, WITH CAUTION
Jan 15, 2013 | Yamaha RX-V673 7.2 Channel AV Receiver...
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
No voice
Check your "main menu" settings. If you are not using a center channel you need to go into "speaker settings" toggle to "center channel" and select "none" If that's not what your question is, post a comment with some more detail and I will gladly help you more. Hope this helps.
Sep 04, 2009 | Yamaha RX-V461 AV Receiver
Center channel drops once unit warms up
You don't have an external amlifuer, do you? You could hook the pre-amp out for the center channel to an external amp and connect the speaker to the amp. That way you could determine if it is the center channel output or the internal amp. Either way you probably need to get it serviced.
Best Regards,
-James
Aug 28, 2008 | Yamaha RX-V659 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-Z11 11.2 Channels Receiver Logo
90 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
