Question about Omega Juicers BMJ330
Omega juicer bmj330 trouble shooting
It will not start. What can I do. I have tried different electrical outlets and taking it apart and putting it back together.
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Sep 03, 2011 | Omega Juicers
How do you take the juicer apart for cleaning?
Undo the latch arms, remove the cover then the clutch nut in the center of the
blade. Everything should lift out.
Apr 03, 2011 | Omega 1000 Juice Extractor
All hooked up but won't start. Electrical outlet working fine.
There may be a reset button on the bottom. Try pushing it.
Nov 08, 2010 | Omega 1000 Juice Extractor
Jack Lalanne pusher is stuck in the shoot, was put is the wrong way. Can not pull it back out. Any suggestions.
Heat or cold makes things small or big. Soak it in warm water or put it in fridge then try to take it apart. Hope it helps.
Nov 19, 2009 | Jack Lalanne Power Juicer (Stainless...
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
I don't know how to take it apart to clean it.
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Manuals for all models of Jack Lalanne's Power Juicers. This includes trouble shooting guide, Instructions on cleaning ect...
Apr 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
How do I replace the latch arm?
I WOULD CALL OMEGA AT 717 561 1105. I REPLACED ONE
ON AN OMEGA 1000 BY REMOVING BOTTOM OF JUICER
TO VIEW LATCH ARM WHERE IT ATTACHES FROM INSIDE
THE HOUSING. YOU CAN FIGURE IT OUT. IT HAS TO BE
PRIED A LITTLE AND SLIPPED UP AND OUT.
Oct 19, 2008 | Omega 4000 Juicer
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Omega Juicers BMJ330 Logo
61 people viewed this question
Top Omega Juicers Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you an Omega Juicers Juicer Expert? Answer questions, earn points and help others
