Question about Robertshaw 9701i2 Programmable 1 Heat/1 Cool Hardwired Thermostat
Troubleshooting robertshaw thermostat - Robertshaw 9701i2 Programmable 1 Heat/1 Cool Hardwired Thermostat
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
My robertshaw 9620 thermostat is stuck on 70 and i can not change setting frim temp or time.
Here's how I fixed my Robertshaw thermostat that was stuck at a 70 degree reading for almost 2 monthes. When I turned on the air conditioner or heater it wouldn't stay on. I removed the cover panel and dusted off the inside which the guy at local hardware store suggested. That didn't work. Then I noticed the words "reset" right on the green circuit board on the left side. There's a very small silver button. I pressed on it and everything reset. Less than a minute later the thermostat is reading the correct room temperature. Now my air conditioner and heater are working properly.
Mar 16, 2014 | Robertshaw 9620 digital...
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Robertshaw 9701i2 Programmable 1 Heat/1 Cool Hardwired Thermostat Logo
83 people viewed this question
Top Robertshaw Televison & Video Experts
Are you a Robertshaw Televison and Video Expert? Answer questions, earn points and help others
