Question about Sewing Machines
How do i change the belt on singer 328k - Sewing Machines
5 Suggested Answers
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
  • 1116 Answers
SOURCE: what size is the bobbin for the 328K singer?
Class 66 is the size.
http://www.sewingmachinesplus.com/sewing-accessories-bobbins-class-66.php
Posted on Mar 06, 2010
  • 16 Answers
SOURCE: I bought a Singer 328K
The Singer 328K "style-o-matic" is a Class 66 sewing machine with a solid handwheel. Like the 328, and most style 66 machines, this one takes Singer Motor Belt # 193077. Any singer vendor should be able to help you and as of this writing (2010) the part runs around $10. In case you have a parts machine around or find vendors less knowledgeable here are some other machines using the same belt: Pfaff 330 Series Singer 127 Singer 128 Singer 15-88 Singer 15-90 Singer 15-91 Singer 185 Singer 185K3 Singer 206 Singer 206K Singer 223 Singer 27 Vibrating Shuttle Singer 306K Singer 306W Singer 319K Singer 327K Singer 327K Singer 328K Style-O-Matic (YOURS) Singer 329K Singer 66 Singer 66-1 Singer 66-14 Singer 66-16 Singer 66-18 Singer 66-24 Singer 66-4 Singer 66-6 Singer 66-8 Singer 99 Class Singer 99-13 Singer 99-31 Singer 99K
Hope this helps!
Posted on Aug 14, 2010
Testimonial: "Now I know what size belt to buy which is very helpful since there are so many of them on the market.."
  • 1564 Answers
SOURCE: does the singer 328K sew backwards?
nope
Posted on Sep 03, 2012
Polyester thread fuzzing on my 328k singer. using an 18 needle on marine vinyl
try changing the needle--just incase the needle tip is damaged
check for burrs in the thread guide area where the top thread runs
or even on the needle plate
Jun 05, 2012 | Singer Sewing Machines
I bought a Singer 328K at a second hand shop. I cleaned and oiled it but the motor just hums and runs very slowly. I think the belt may need tightened or replaced. Is it possible to do it myself and...
Hope this helps!
Aug 14, 2010 | Singer Sewing Machines
Singer 328k bobbin winder replacement
Nov 22, 2009 | Singer Sewing Machines
Gathering thread under the clothes
check needle to see if it's in backwards
check needle to see if it's bent-lay the needle on a flat surface & roll the needle over, if the needle doesn't roll good replace
check to make sure machine is threaded right
check for lint or loose thread fragment in bobbin area
Jun 02, 2008 | Singer 3116 Simple
Singer Sewing machine
I found the same numbers on my Singer, but learned that the 13608M is not the serial number. I finally found it on the bottom of the machine. It typically begins with either a single or double letter. You can find the Serial No. and Year of Issue at http://www.singerco.com/support/serial_numbers.html. You can also order a replacement manual. Another helpful site might be http://www.ismacs.net/Singer/singerdates.html.
Good luck.
Mar 27, 2008 | Sewing Machines
Singer industrial sewing machine
It might be the way you're asking that's confusing the problem. It's simple to remove the hand wheel, slip the belt over the track, and then replace the hand wheel. It really depends on the model of your machine - is it by chance a 328K?
Martie Johnson (USA)
Nov 25, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
