Question about Advueu Technology AMW-F196B
AMW F199B no RGB input
This monitor was recently given to me. When I turn it on, the green light comes on but then a couple seconds later I get a message on the screen saying no RGB input. The button then turns yellow. I have to push the button again to get red the again to turn it back on to get green and it goes through the same process. The video cable on the monitor is a hard-wired VGA cable. I can't get to any kind of a menu to try and change input preference.
3 Suggested Answers
SOURCE: AMW-F199B intermittent turn on
I had same problem. I found that there were 2 capacitors on the power supply which were bulging which means that they were faulty. I replaced them and unit worked ok. The values for the capacitors were 680 uf / 16V. If anyone wants any more detailed information, let me know.
Posted on Jan 08, 2008
SOURCE: AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Posted on Nov 09, 2008
Color is not bright and looks green
This can be caused by an incorrect signal feeding your LCD. Normally, the green channel can carry the synchronizing signal along with the green part of the picture, but if it does not terminate properly it will make the whole picture green. The Syncmasters usually have Composite, RGB/Yr-y b-y, VGA and RF inputs. It could also be that the LCD is in RGB mode and you are feeding it Yr-y b-y. (or vice- versus). Make sure, if your using the component input, (RGB) that the source matches the LCD setting. RGB to RGB and Yr-y b-y to Yr-y b-y.
Jun 12, 2011 | Samsung SyncMaster 920NW Monitor
AMW model MW19E-bcd doesn't come on
stepstve, You will find some vid clips on monitor tear-down at YouTube if u search under LCD repair and or bad capacitors. Is this monitor one that has a "lay on floor" brick power supply, or does monitor plug directly into wall outlet? If you open monitor look for capacitors with swollen tops of their aluminum can housings. Take pictures or video of what u do!!!! Just so u can put it back together with no leftover parts!!!! Have a friend help you. How old is monitor? Also search under "cold cathode fluorescent tubes" for information on how they operate.
you should also understand some basics of "switch-mode-power-supplies" and how they operate. Bye for now. lmistyrel @ aol.com
Sep 15, 2009 | Advueu Technology AMW-F196B
I was given a Xenon flat screen monitor. The back has 4 usb ports and 1 usb input and an analog rgb port. It came with no cables. Can I just use a usb cable or do i need the analog rgb cable? Also when I...
The USB hub/connections cannot be used for driving the monitor... It is only an extra feature so that you can connect USB devices (such as a mouse & keyboard or flash drive) at the monitor instead of the computer ports.
You must use the RGB/VGA connection to use the monitor.
When you turn ON the monitor, it should "announce" itself with a logo...
When you were given the monitor, were you told that it works?
Please connect the monitor and comment back...
Thanks!
Sep 10, 2009 | Computers & Internet
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
My F199B seems to have a bad display after
You need to download & install the Windows 7 druvers for your graphics card. Once this is done your display should be fine. Hope this helps.
Jun 26, 2009 | Advueu Technology AMW-F196B
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
Dec 14, 2007 | Advueu Technology AMW-F196B
Advueu Technology AMW-F196B Logo
43 people viewed this question
Top Advueu Technology Computers & Internet Experts
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
