Question about Actiontec GT701C DSL Modem
Firmware? Got a Verizon branded Actiontec GT701C DSL Modem. Where can I find the latest firmware for it? Please help.
  • 45 Answers
SOURCE: My actiontec verizon dsl wireless modem/router loses it's connect
http://www.actiontec.com/support/index.php
Select the model and then download the firmware. Instructions are also included but may vary depending on model.
Posted on Jan 07, 2009
  • 11 Answers
SOURCE: I have a Qwest Actiontec modem that has worked
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
Posted on May 07, 2009
  • 144 Answers
SOURCE: Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Posted on Jun 05, 2009
Geekman
  • 32281 Answers
SOURCE: I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 31, 2009
SOURCE: Actiontec Modem Won't Work!
Pull out the power plug on the back of the modem, then reinsert it. Should reset the modem
Posted on Jul 23, 2011
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
I have Verizon DSL (768 kbs). For the past month, my download speed has slowed down, sometimes to as low as 30 kbs, until I turn off and turn back on the modem. Any ideas if this is a modem problem or with...
This can still be corrected by doing a firmware upgrade, you can get that firmware from Verizon and that will resolve the speed problem that you have....
Nov 03, 2009 | Actiontec (GT704WG) Router
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
Jun 05, 2009 | Actiontec GT701C DSL Modem
Jan 07, 2009 | Actiontec (GS503AD3-01) Modem
I have AT&T DSL and want to install an Actiontec 54 mbps wireless
If the modem was pre-programmed for another service, such as Verizon, you will have to plug the modem into a wall and hold in the reset button on the back of the modem until it resets. Then load the AT&T software IF they provided you with such - the walkthrough is actually pretty good. If AT&T did not provide you the Actiontec or the software, you will have to go to Actiontec's website and download the Actiontec Installation Buddy and also follow the directions for downloading the non-proprietary version of the firmware (WARNING: do not update the player's firmware if ATT &T provided you with the Actiontec; the non-proprietary firmware will make the modem useless toward whichever service provided you with the Actiontec). Take note of the numbers taped on a sticker underneath your Actiontec - MAC Address, etc. You may need this information to complete the installation. Also, download the Actiontec manual - it will take you through the process, but it is not going to be easy to follow - know in advance that it is going to take time.
As you go through the Actiontec Installation Buddy process, it will prompt you to do a modem test - make sure the Actiontec is connected to the phone line and to your computer (via an Ethernet cable). It will do a modem test. If the modem test fails the first time, turn the Actiontec OFF, wait 10 seconds, and turn it on again. Try the modem test again - should work.
If AT&T did NOT provide you with the Actiontec, your task is going to be a bit tricky. If AT&T DID provide you with the Actiontec, it might be better to call their technical support for a walkthrough.
-Tha Mp3 Doctor
Jan 07, 2009 | Actiontec GT704WG Wireless Router...
Westell 2200 modem
You have options definitely. You can get it through verizon, they'll ship it to you free of charge. You can also buy it at any local store near you. If you're going with the second option, just make sure you're getting either an Actiontec or Westell brand, because those are the only modem that Verizon supports, even if you buy it outside. Since you're going to upgrade your modem, I suggest getting a Westell 7500 or an Actiontec GT704, both are wireless capable already. If you use XBOX 360, I suggest getting Westell 327 or Actiontec GT701 or GT704.
Oct 29, 2008 | Westell Wirespeed LiteLine 6100...
GT704-WG with Verizon firmware
I just flashed my verizon modem FT704-WG with the actiontec update upgrade301060gt704wg.img. I then selected "Obtain an IP Address through DHCP" and bam away we go... working better than verizons version.
Jan 21, 2008 | Actiontec GT704WG Wireless Router...
Actiontec GT701C DSL Modem Logo
53 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
