Question about Garden
Were is oil drain plug on bmc 20 inch cut mower
I cannot find oil drain plug on my mowerany ideas please
  • 15 Answers
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Posted on Apr 23, 2009
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
  • 7 Answers
SOURCE: oil drain plug how do you find it
the oil drain plug is underneath the motor by the blade you can use the socet wrench to open it
Posted on May 02, 2009
defadad
  • 351 Answers
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Posted on May 11, 2009
woobie dog
  • 1273 Answers
SOURCE: put the wrong oil in my riding lawn mower. Should
It should be OK, provided no damage was done to the engine when you ran it. Hopefully, you caught it quickly. Just to be on the mechanically safer side, I'd change the oil again. If your mower is equipped with a filter and you didn't change it after the 2 cycle happening, change it, too. If you have a filter, always fill the filter with oil before you mount it if the orientation of the filter allows. Fill the engine with oil. Check and start. There may still be some smoking until you clear the residue out, and you may even have to clean your spark plug(s) a time or two. You should see a gradual improvement in your exhaust plume. If any damage had occurred to your engine, you will likely hear abnormal sounds. If this is the case, shut the mower down immediately and investigate forther, with your local professional.
Best Regards! --W/D--
Posted on Jul 11, 2009
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Where is oil drain plug
On the right side of engine towards the bottom, a square plug
at the drain plug.
Aug 21, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Will not start after changing the blade
what side did you tip it to did oil drain into the carb did gas drain into the cylinder flooding it out remove the spark plug and look pull the engine over with the plug out and that can push it out
Apr 25, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Describe your Yard - Man 160cc, 21" Self - Propelled Lawn Mower Problem i don't know where oil drain plug is
You'll find most Briggs and Statton Engines have an oil drain plug directly on the bottom of the engine. It is square and can be removed with a 3/8" ratchet with no socket on it (you just stick the ratchet or ratchet with extension right in the hole and turn it CCW. When you put it back in, make it tight, but not too tight or you'll crack the block of your engine (trust me!). Some engines such as the Honda's do not have an oil drain plug and you need to just dump the oil right out of the fill spout. Awkward. Your engine will hold between 20 and 22 oz of straight 30 WT oil; do not overfill it. Put in about 20 oz. and let it sit for a few minutes then check it on your dipstick. Hope this helps and best of luck to you.
PS: Always remove the spark plug wire before working on your engine! Turning the blade by hand could start your engine and cut your hand off!
James
Sep 18, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Troy-Built Series 550 mower with a Briggs & Stratton engine. I cannot find the drain plug. Is there a good diagram available?
Most professional shops no longer drain the oil through a drain plug because of all the covers under the engine. With your Briggs and Stratton engine, the best way is to drain through the dipstick. You can purchase a suction device to **** out the oil, or you can drain it. To drain, place you mower on the tailgate of your truck, or on the picnic table. Grab a drain bucket, remove the dipstick and tilt the handle to the ground. The spark plug should be pointed straight up into the air. Might be a good idea to do a test run before removing the dipstick, so you will know exactly where to hold the bucket. All 20 ounces of oil will drain through the dipstick in about a minute if the engine has been warmed up. Refill with a good quality SAE HD30 weight motor oil. Remember...only 20 ounces. Check the oil level after filling before you start the engine.
Good luck.
Sep 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Where do i change the oil on 5.5 hp. 21 inch cut mtd push mower
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Apr 04, 2010 | Mtd 22" Yard Machine Push Mower
How to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
Jan 04, 2010 | Poulan Pro 22" Self Propelled High Wheel...
What kind of oil do I use and how do I hange the oil? I have a walk behind mower model HD4QN20RF.
you use 30HD only 20 oz.. There is a drain plug under the deck in the bottom of the mower. It takes a 3/8 " ratchet and an extension. Push the handles down, Disconnect the spark plug wire, Mower the blade to one side, Take out the drain plug, put a container to collect the used oil under the mower, Put the mower back down, And it will drain the oil. Check and make sure you are getting the oil in the container. When it has drained the oil, Put the plug back in, put new oil in the mower. Hope it helps.
Good day.
Oct 17, 2009 | Garden
Oil drain plug
Apr 20, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
