Question about Whirlpool Gold GGE388LX Double Oven Freestanding Electric Range with Delay Bake, Accubake, Self
The control panel is not working
When I use the stove or oven, the clock screen turns off and will blink 3.0 and a red light flashes in the bottom left corner. Then the whole screen goes dark. The stove top and oven still work.
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
Code S ab on screen
try pressing and holding the clock tab on the erc for 5 secs
this will usually cause the sab to flash 3-4 times and then retrun to normal operation mode
Oct 17, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Whirlpool Gold GGE388LX Double Oven Freestanding Electric Range with Delay Bake, Accubake, Self Logo
29 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
