Question about Actiontec GT701C DSL Modem
Firmware Got a verizon branded GT701C. Where can I get the latest firmware for it.
Sim card not recognized
Barbara-
Some of the latest Verizon phones require a microSIM whereas the Droid Bionic requires a miniSIM. Please go to a Verizon corporate store where they can get you the appropriate size. It shouldn't cost you anything. Don't leave until they have it working.
Mark
Motorola Support
Aug 03, 2014 | Motorola Mobility Verizon Wireless Droid...
Tip
Motorola MotoQ Verizon Firmware Update Download
Download Motorola Moto Q Verizon Firmware Update
Would you like to update the Verizon system software of the Motorola Moto Q Cell Phone?
Do you need to reflash the Verizon firmware of your frozen Motorola Moto Q Cell Phone?
Follow this link (& click FREE) to download a pdf version of the Motorola Moto Q Cell Phone upgrade documentation.
I hope that helps.
____________________________________________________________________
Motorola MotoQ Manual Download
Motorola MotoQ Update Manual Download
on Jul 14, 2010 | Motorola Mobility Moto Q
Hello, my d-link DIR615 type D1 disconnects himself usely about 3-4 times a day. With a reboot from the d-link it works again after a while. Can this problem be in the DNS? or can you please tell me what...
I had a similar problem in the past. I would suggest the following solutions:
1) Download the latest drivers for the D-Link DIR-625 or D-615 Router at the manufacturer's website DIR-625: http://www.dlink.com/products/?pid=501
DIR-615: http://www.dlink.com/products/?pid=565
-Make sure to download the correct drivers for your operating system (XP, Vista, Windows 7).
2) Download the latest firmware for the D-Link DIR-625 or DIR-615. It is available through the same listed websites.
Note: Make sure to use direct connection for firmware upgrades so that it upgrades securely without errors.
3) Make sure the modem is up to date. If it's your modem, then upgrade drivers and firmware by googling the appropriate model number and brand of the modem.
4) If it is not your modem, you can still upgrade the drivers and firmware. Further assistance should be available through your ISP (Comcast, Verizon).
5) Sometimes a connection may be disconnecting because the firmware for the connection via FiOS/DSL may not be upgraded in the infrastructure outside your house. To solve this issue, call up your ISP and tell him that you are disconnecting several times a day and ask if firmware is up to date.
6) It may be a faulty modem. If so, call up your ISP and they should replace it for free (generally).
7) Fault router may entail customer support at D-Link. Just contact through email and check your warranty. They may help you even if the product is out of warranty (happened to me).
Nov 22, 2010 | D-Link DIR-625 (790069292637) Wireless...
Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Jun 05, 2009 | Actiontec GT701C DSL Modem
Website to download latest LG Venus mobile firmware
you might want to try reinstalling the firmware for the phone. you will need to find a piece of software called lg download. and then also to find the drivers file called something like the vx8800dll.msi for the lg download software. then also need to find the firmware image file to flash onto it. try humpa's verizon downloads site. good luck
Mar 19, 2009 | LG Venus VX8800 Cellular Phone
Garmin 760 Blutooth pairing
I also have the 760 & the first gen Boulder (before the front speaker was added). I had the same issue with the M07 firmware (the latest you can get over the air), but took it into a Verizon store & updated it to M09. I am now able to pair the two devices.
Jan 04, 2009 | Garmin Nuvi 660 GPS Receiver
GT704-WG with Verizon firmware
I just flashed my verizon modem FT704-WG with the actiontec update upgrade301060gt704wg.img. I then selected "Obtain an IP Address through DHCP" and bam away we go... working better than verizons version.
Jan 21, 2008 | Actiontec GT704WG Wireless Router...
My razor cell keeps roming
Try dialing *228 to update your roaming preferences. It should connect to verizon's automated roaming update service.
Unfortunately, it won't normally update if you are not already on a Verizon tower. If *228 will not connect, also try *22804, which attempts to push it through to the nearest Verizon tower, or *22890.
If you do get through, it will give you a welcome message, and ask you to select option 1 to reprogram, or option 2 to update roaming preferences. You will need to select option 2.
If you do not get through, unfortunately you will have to stop by a Verizon Wireless Corporate owned store and speak with their tech department. They will be able to tell you if you have the latest PRL (preferred roaming list) and also check to see if you have the latest firmware (which could be part of the issue). They will have the tools to manually reprogram the roaming listing in the phone.
Jan 21, 2008 | Motorola Mobility RAZR V3
How do I upgrade the firmware on my VDI-604 or VDI-624?
Step 1 Download the latest firmware. Click here to download the latest firmware for the VDI-604 - http://support.dlink.com/products/view.asp?productid=VDI-604#firm Click here to download the latest firmware for the VDI-624 - http://support.dlink.com/products/view.asp?productid=VDI-624#firm Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click on the Tools tab at the top and then click Firmware on the left side. Step 5 Click Browse and navigate to the .bin file you downloaded in Step 1. Select the file and then click Open. Step 6 Click Apply. It may take a up to 30 seconds for the firmware upgrade to complete. Step 7 When prompted click Continue. The firmware upgrade is now completed. Step 8 If you get a Page cannot be displayed or similar error after clicking Continue, close the web browser and re-open it. Repeat Step 2 to login to the web-based configuration.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Actiontec GT701C DSL Modem Logo
47 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
