Question about Smeg 23 in. SE64 Gas Cooktop
Stuck auto ignition
My auto-ignition is jammed and the connector on each hob is sparking constantly, as if the knobs were pressed down (which they aren't). Suggestions?
  • scottiejay Jan 12, 2008
    this is the exact same thing happening to me. although the clicking seems to reduce while the oven is on.
  • 183 Answers
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Posted on Sep 01, 2007
2 Suggested Answers
SOURCE:
  • 1462 Answers
SOURCE: Stuck auto ignition
try easing each knob upwards a bit.
Posted on Jul 15, 2008
The ignition on my hob is sparking every second or so constantly on it's own? The knobs don't seem to be stuck down or anything obvious. All four ignition points on the cooking points are visibly sparking.
I think the problem lies at your knob mechanism. Try to service the mechansm. Currently the possible problem is lies at the contact point(electrical) might accidently contact without pressing down the knob. This normally occur when it is hyper press or there are grease in between the contact. Possible solution is replace the damage knob... or repair it.
Aug 19, 2010 | Cooktops
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Constant ignition clicking on Dacor cooktop
try cutting the power to the stove for half an hour, see if that resets it
regards
Nov 26, 2008 | Neff 28 in. T2764 Gas Cooktop
Stuck auto ignition
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg 23 in. SE64 Gas Cooktop Logo
1,103 people viewed this question
Top Smeg Cooktops Experts
Steve Allison
Steve Allison
Roger Davis
Level 1 Expert
Ismael Rodriguez...
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
