Question about Garden
Honda 2600 psi pressure
Pull rope is hard to pull and kicks back. It seems pressure builds and isn't released. Is there some kind of pressure release valve adjustment.
    Sergeant:
  • 406 Answers
Honda gx series does have a decompression lobe in cam if you remove the valve cover you should see the exhaust valve open twice while your pulling the rope measurements r exhaust .008 and intake is .006 thousands of an inch.just use a 10 mm socket on the adjuster and tighten as necessary:):)
Posted on Aug 05, 2013
  • 12 Answers
SOURCE: Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Posted on Apr 06, 2009
  • 56 Answers
SOURCE: Pressure will not kick in consistantly
The circled part is the one that usually will stick.
Posted on Jan 15, 2010
  • 394 Answers
SOURCE: i 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Posted on Apr 23, 2010
  • 8 Answers
SOURCE: Too much pressure.
You need to keep the trigger pulled every time you start and you need to run the water for 3-5 minutes wide open before you start. Zero air should be in the line or this could cause it to **** out. You probably damaged the pump at this point.
Posted on May 27, 2010
  • 5 Answers
SOURCE: i change oil on my 3700 psi honda motor pressure
Most likely has nothing to do with oil change. Have someone hold the trigger on handle open to relieve pressure on system/pump , this will make engine turn easier when you pull rope.
Posted on Oct 02, 2010
Rope pull start is stuck, won't pull out
Check the oil level, if it's very low or burnt then it may have siezed up internally.
It could also be that be that the cylinder is filled with oil or fuel.
if the washer was tipped over the fuel or oil may have migrated in to the piston combustion area.
Oct 20, 2014 | Honda Black Max 2600 PSI Pressure Washer
I have a honda gx 390 that kicks back when i pull the rope to start
The ignition timing may be too advanced . Some times if the pull start rope is not pulled hard enough it will kick back, The ignition fires just before top dead center , if not pulled hard enough it will kick back.
Oct 15, 2014 | Garden
How do I replace pull starter rope?
remove the pulley housing cover.Remove the remaining rope pay attention as how its' threaded.Loop the new rope exactly as the old one.That's it
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
Pull starting rope Broke
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght
Pull Stirng rope snapped on my Homelite 2400PSI Pressure washer
Installed improperly or the rope is not the proper size.
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght.
Oct 21, 2012 | Mi T M Jp-2403-0Mhb - 2400 Psi 2.4 Gpm,...
Exha 2425 pull cord jammed
I'm not sure if this is an attempted repair or whether this just "happened" but here is my repair procedure. Jammed could be worn or dirty rope or rope improperly sized for the machine...or crushed housing. A broken or slipped spring can seem jammed. Sometimes a spring can be re-bent on the inner most winding tab to catch on the housing.
Oct 21, 2012 | Honda Black Max 2600 PSI Pressure Washer
Honda 13 hp won't start...back fire's
Assuming that the engine has not been taken apart and timing is set correctly. Have seen this often. Usually valve adjustment. Adjust valves as per manual so that compression release is working. If compression release is not working after adjustment check for faulty cam.
Oct 22, 2011 | Honda Landa PG 3500 PSI Pressure Washer
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
I change oil on my 3700 psi honda motor pressure washer motor and pump and after i done that the tigger rope is to hard to pull looks like some who is pressure some where can some one help me whit this...
Oct 02, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
