Question about Buffalo Technology Buffalo MiniStation Plus HD-PNTU3 500 GB External HDD - Red
Harddrive enclosure Hi my hard drive is not working. Ive opened the case and it seems one of the small pins has broken away. What sort of enclosure is compatible with my hard drive?
    New Friend:
    Problem Solver:
  • 15 Answers
Depending on the size
2.5" if it's a small one (no power adaptor needed)
3.5" if that's the big one (desktop hdd with power adaptor)
Posted on Jul 25, 2013
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
My model BC1TB has not backed up for 10 days, and does not turn on when plugged into AC power. It it dead?
It may not be your hard drive but the enclosure casing that is not powering up your drive. If you are a self do'er, open the enclosure and take the hard drive out. The hard drive should be a SATA. Do only this if the warranty has expired otherwise you will void the warranty. You can purchase another enclosure for your SATA drive. To test if the hard drive is still operable, you will need to open the case and connect the hard drive to a SATA controller via a data cable/15 pin power connector. If you're a novice, I recommend getting a hard drive docking station which will connect via usb to your computer/laptop.
Nov 23, 2013 | Computers & Internet
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
External hard drive was dropped and now no power
You may have accidently broken some of the internal components of the external enclosure. If you have the know how, you should take the hard drive out and test it in a computer to see if the hard drive is still good. If the hard drive is still good, you can get away with buying another enclosure. If the hard drive isnt good, your better off just buying another external drive.
Mar 05, 2011 | Seagate USB 2.0 External Enclosure + 400GB...
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Jan 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi i have this "Western Digital WD Passport 250GB Portable" Problem Now! broken one of that pin where usb connect to hard dirve .
I did this once had to solder an interconnect to the other side of the connection of the PCB then use a small croc clip to make the other connection worked just fine just not aesthetic
Mar 21, 2010 | Western Digital WD Passport 250GB Portable...
Lost the power lead
Yes it is, might be more cost affective to just buy another compatible enclosure for $40 or less and move it inot replacement case.
Turk
Oct 07, 2009 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Jun 04, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Jun 01, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Buffalo Technology Buffalo MiniStation Plus HD-PNTU3 500 GB External HDD - Red Logo
61 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
