Question about Samsung PS42P2S 42 in. Plasma Television
Pc appears on screen and then no plasma input after about 1/2 hour
HidefhfhfieiikkfjjfkjfjgjhhfkdfeoighorwGHFD;OAHJLIEjhoierjhfbiufhlkvmnkfdljhbfiolksfhlksfjhflkdjfiglkhrfighflkjhgfjlkghifdhglkrjfkjgkgofjhopfjhoiigjpoehoierjoigehoierhpehirgerojhierhpoejhoruhieruoerpigoruhjpoerugrhureopgrepueophepupojrpoepupogririerpouheuhpoerporugporuorhurpoioerupoeueropupopoerpoerupoererupoepopoeugjrgrijgrijpjpperjjgerjrejuregjrrgihrggrgjjjjjfjfigoiriiririijjfifjjjifiihirguhguihgoijgoihfsgsjoighsfigohsoighskgjkfslghlkshskghs
Posted on Dec 04, 2013
DEll 42" plasma TV. The
do u have any wash out fetures in tv menu all white light this will stop that lite glitch i have samsung had same isse in my menus we have wash out feture that throw brite white light on screen that helps get glitch out ok cheak menus for screen burn in protection ok adjust it thx nick
Feb 11, 2008 | Dell W4200 42 in. HD-Ready Plasma...
A Green Blotchy Area about 9 in oval in the upper part of teh screen
Plasma with Burn in within 3 years, I bet. I've seen Week old plasma's with burn in. Plasma technology is not as good as some would make it out to be. Due to the nature of the physics of the device, it is susceptible to something called "Burn-in" When an image of any form is displayed for long periods of time on a Plasma display, they start to literally burn in or wear out that part of the screen faster than a moving picture elsewhere on the screen. ie. If you have a television that is always on one channel and that channel always displays the little logo in the bottom right of the screen (abc, cbs, speed...) that kind of thing, you will eventually actually be able to read that logo even when the plasma tv is turned off. Check your manual or the manufacturer's website for your tv, and somewhere in there, it will refer to a "half-life" of the tv. ie. if your model has a 2000 hr half life, after 2000 hours of viewing, the display can at maximum, put out 1/2 of it's total brightness output. after another 2000 hrs 1/2 again as bright. and eventually it will be so dim that it's unusable. This is a fault with Plasma technology, LCD does not have this issue. CRT used to have this issue, but advances in technology have lowered this risk. So. What you are seeing is remnants of a bright image that was more often shown on that part of the screen than anywhere else on the screen. There is nothing that can be done other than replace the unit (or the screen, but it's easier to change the whole unit). if you've had this unit for 3+ years, you did pretty well. doing the math, if you only use your tv for 2 hours a day, for the 3 years you own it, assuming a 2000 hr half life, you've broken that limit. meaning that you will have parts of your screen that are very likely half as bright as others. Nature of the beast (plasma). This is why they are not as popular as they are advertised. Try an LCD next time.
Aug 06, 2007 | Pioneer PureVision Pro-1000HD 50 in....
Whats the difference between a LCD and plasma
Answer: Outward appearances are definitely deceiving when it comes to LCD and Plasma televisions. Although both types of televisions are flat and thin, they employ different technology in an attempt to deliver similar results. Plasma TV Overview Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element). Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images. LCD TV Overview LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation). Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer. Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself. Plasma vs LCD The ADVANTAGES of Plasma over LCD are: 1. Larger screen size availability. 2. Better contrast ratio and ability to render deeper blacks. 3. Better color accuracy and saturation. 4. Better motion tracking (little or no motion lag in fast moving images). The DISADVANTAGES of Plasma vs LCD include: 1. Plasma TVs are more susceptible to burn-in of static images. 2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images. 3. Does not perform as well at higher altitudes. 4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements. LCD television ADVANTAGES over Plasma include: 1. No burn-in of static images. 2. Cooler running temperature. 3. No high altitude use issues. 4. Increased image brightness over Plasma. 5. Lighter weight (when comparing same screen sizes) than Plasma counterparts. 6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans. DISADVANTAGES of LCD vs Plasma televisions include: 1. Lower contrast ratio, not as good rendering deep blacks. 2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets. 3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public. 4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you. 5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions. For a more detailed look at the LCD and Plasma comparison, check out: Should I Buy an LCD or Plasma Television?
Jan 18, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Pc ready
There is a PC/DTV RGB input area with two audio jack inputs.  The input is a standard 15 pin PC jack. Hook it up to your PC video card input.  You can get the audio cable from Best Buy or a electronics store...split RCA on one end and the headphone jacks on the other to your PC. Then select the TV/Video source button on your remote until you see PC/DTV YPbPr screen appear.  It will search for the signal, find your PC and display the screen. You may have to go to MENUE on your remote to adjust the HDTV (1080i) frequency.... an option that only appears if there is something hooked up to the PC/DTV RGB signal input.
Nov 26, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
Sep 09, 2007 | JVC GM-P420UG 42 in. Plasma Television
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Samsung PS42P2S 42 in. Plasma Television Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
