Question about Lexicon Audio Players & Recorders
Lexicon alex factory reset - Lexicon Audio Players & Recorders
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
I need the full factory reset procedure for my HP OfficeJet Pro 8500 A909N
Hi! this is Alex Walker call me +1(518)348-9393 i am expert to help you for this issue thank you
Aug 10, 2017 | Office Equipment & Supplies
How to reset LEXICON MX 300
Factory Restore The Factory Restore function erases all user programs and system settings and returns them to their factory state. To restore the MX300 to the factory state, follow these steps:
1. From the Factory Restore screen, turn Knob A until the HOLD screen appears. Press the Exit button to abort the Factory Restore procedure.
System Menu
A FACTORY RESTORE HOLD (STORE)
2. Press and hold the Store button until the white progress bar has completely disappeared. This will complete the restore procedure and the MX300 will be returned to its factory state.
May 08, 2011 | Audio Players & Recorders
On powering up, the lexicons LCD display Audition light flashes for about 6-7 secs, then "21" appears then"UP". After this none of the buttons/Diald work-it just freezes. I have been...
hola tengo el mismo problema, me han dicho que actualizando el firmware de la lexicon mx200 se soluciona pero resulta que mi pc no reconoce el dispositivo via USB para actualizarlo, alguna solucion?? muchas gracias
Mar 18, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Lexicon omega usb board burn in two places part[80-0112-b]digital B D
One can burn up equipment if you have powered parts of it from different sources...such as connecting things together that get their power from different receptacles. Ground bounce and fault currents of defective equipment can burn up things. You will probably have to send your unit back to the factory for repair.
Jan 08, 2011 | Lexicon Omega Desktop Recording Studio
Dsi is locked on alex rider stormbreaker thq and cannot play any games?
FACTORY RESET CODE
HOLD DOWN THESE KEYS TOGETHER AT THE SAME TIME TO RESET
HOLD DOWN ..LEFT,RIGHT,START,SELECT TO RESET YOUR DSI TO FACTORY SETTINGS
Jan 08, 2011 | Nintendo DSi Black Console
Is there a way to reset the Lexicon Omega (power up holding down buttons?)
You can reset your Omega by powering on the unit while holding down the Mic USB button and the Line 3 USB button.
Dec 02, 2010 | Lexicon Omega Desktop Computer Recording...
My Lexicon Alex is malfunctioning, where can I find parts?
I don't think it's broken. I think you've cleared some registers (probably number 5 from your description, maybe more) and now you're "us[ing] cleared registers as loop points." This means that you're looping 1-2-3-4 then back to 1 again. This is actually a feature of the Alex and it's awesome as long as you're using it intentionally :) If you don't know you're "using" it the unit have symptoms similar to what you're describing. It's possible that it is broken, but it's more likely that you're in this mode.
I attached a pic of my user's manual.
Also here are the directions as printed in the manual to clear or restore a register (i.e. a number spot on the dial):
  1. Briefly press STORE/CLEAR until a minus sign (-) is displayed.
  2. Press and hold STORE/CLEAR. If you were in preset mode, the register LED will go on, indicating that Alex has automatically switched to register mode -- selecting whatever register is indicated by the position of the REGISTER/PRESET knob. The "-" symbol in the display will flash, indicating that the CLEAR function is armed.
  3. Releasing STORE/CLEAR will clear the displayed register. The display will flash briefly to indicate the clear was successful. (The ID number of any cleared register flashes when selected with the REGISTER/PRESET knob.)
To restore a cleared register, simply repeat the clear operation with the "+" displayed.
Mar 05, 2009 | Lexicon Omega Desktop Recording Studio...
Top Lexicon Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Electric Dime
Electric Dime
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
