Xerox work centre pro c2636 start up
Pressing the start button will start to power up the copier but when released the copier shuts off. Holding in the start button will enable power to maintain on but copier will not boot up.
    Master:
  • 966 Answers
Did you try turning power off at source and after a minute plug it in?
Posted on Jul 24, 2013
SOURCE: error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Posted on Jun 12, 2008
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
Chintu-KPV
  • 202 Answers
SOURCE: Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
Posted on Nov 23, 2008
  • 193 Answers
SOURCE: how do I set up scan for my xerox workcentre pro
go to xerox website..user guide
when all else fails..follow the instructions
Posted on Dec 03, 2009
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Workcentre Pro 2636 giving error message of: Clear Jam in area 1. we have done this with no luck. Have opened and cleared all areas, even shut the machine down and started back up with no luck. Any...
From past experience this is more often than not caused by a little tiny piece of ripped paper still stuck in the machine somewhere. Turn all rollers and have a really thorough check, especially inbetween the rollers and under any clip down areas on the rollers too..
Jan 27, 2011 | Xerox WorkCentre Pro C2636 Color Copier
Printer is saying "fuser error- call for service"
You will have to replace the fuser unit.
Google a business called The Parts Drop and give them a call. They are roughly 200-250 dollars to replace
Dec 13, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Change k toner cartridge
The machine is asking for a Black Toner
If you have already changed it, double check that they ordered the correct part number, 006R01175.
It is also possible that there is something wrong with the toner you've gotten, if it's 3rd party or rebuilt etc.
Whit
Item, Inc.
Sep 10, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Change belt cleaner?
You have to move or remove the finisher, depending what finisher you have.
Open the door on the right side of the machine . It is about 4 inches high and 14 inches wide.
Open the front cover and move the black bar to the down position as if you were replacing a drum.
Then on the right side, you slide the transfer unit out about 4 or so inches. On the front of that unit there are 2 torx screws held together with a black plastic strip. Remove those 2 screws, remove and replace the cleaner.
Dec 31, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Fuji xerox document centre C250
Aug 02, 2008 | Xerox WorkCentre M123 Copier
29 people viewed this question
k24674
jasbo
jasbo
