Question about ASUS EBXB202BKX0023 Eee Box - Black PC Notebook
Can Asus n56VJ-wh71 screen can be upgrade to FHD?
My laptop dell vostro 1015 local hard disk instaaler
Posted on Jul 24, 2013
Software upgrade for Veon tv model # VN40HB28LED
Veon VN3278LCD FHD Instruction Manual Visit this site to get its manual. It has all detail bout the firmware upgrade procedure.
Dec 11, 2016 | Televison & Video
Go for warranty the mobo is dying or the lcd
To be honest i didnt understand the question right now im on a asus and yes there is alot of problems so yes do the waranty
Sep 28, 2014 | ASUS Open Box ZENBOOK UX32V-DDB71 13.3"...
Asus transformer t300
Yes, there should be no problem.
Why do you not upgrade to Windows 10. It is free. Go to Microsoft.com to get details.
Aug 12, 2014 | ASUS Transformer Book T300LA-XH71T Tablet...
Asus manuals
Not seen a manual as such but a dummy or similar guide to Android is likely to have one.
Most android keyboards including jellybean (4.2) are pretty standard.
The up arrow is shift for capitals and hold for a couple of seconds to get all caps rather than one and then return to lower case.
Bottom from right - ?123 is for numbers and symbols and it toggles.
The symbol next to it is for speaking commands rather than type.
long blank is the space bar, then dot,
Left arrow is carriage return or enter. Above this the x with white arrow is backspace delete. A multidot symbol toggles the keyboard on and off the screen.
Normally when you enter a field on a form the keyboard automatically appears. It also appears when you enter a browser address box etc.
Aug 07, 2014 | ASUS MeMO Pad FHD 10 ME302C-B1-BL 32 GB...
Will installation of a asus miracast dongle allow me broadcast from my asus s400ca to my LG TV wirelesslyasus asus support
ASUS Miracast Dongle lets you experience Full HD wireless entertainment and lets you stream your favorite movies, videos and photos through to any compatible large screen TV. Easy to set up and play, Miracast Dongle supports dual-band wireless (2.4GHz and 5GHz) and HDMI to ensure no latency in signal transmission.
  • Compatible Model ASUS MeMO Pad HD 7/ME173X
    ASUS MeMO Pad FHD 10/ME302C
    ASUS MeMO Pad FHD 10 LTE/ME302KL
    Nexus 7 (2013)/ME571K/KL
    ASUS Transformer Pad/TF701T TF103C
    ASUS Fonepad 7 /ME372CG
    ASUS MeMO Pad 10/ME102A
    ASUS MeMO Pad 8/ME180A ME181C ME181CX
    ASUS MeMo Pad 7/ME170C ME176C ME176CX
    ASUS Fonepad Note6/ME560CG
    ASUS FonePad 7/FE170CG
    ASUS FonePad Pad 7 Dual SIM/ME175CG
    ASUS The new Padfone Infinity/A86
    ASUS VivoTab Note8/M80TA
    ASUS Transformer Book/T100
    ZenFone/A400CG A450CG A500CG A501CG A500KL A600CG
    PadFone mini/PF400CG
    Padfone S/PF500KL
ASUS Miracast Dongle Specifications
Feb 06, 2014 | Computers & Internet
Can I replace the charging port in my Nexus 7 FHD 2013 16 GB tablet
If it's just loose, you can snap it back in. If the port is broken off the ribbon though, you can always try to replace the broken part yourself first. search model name plus "repair guide" on any search engine.They will show details about about part replacement etc. in detail. There are other websites that sell all the replacement parts, one of the bigger ones is http://portatronics.com (646) 797 2838. Then for the repair itself you can venture to do it yourself, or better ask a friend who has done a similar repair before.
Jan 06, 2014 | ASUS Nexus 7 FHD Second Generation Tablet...
ASUS N56VJ BEEPING
Saltrock the beeps you hear are BIOS Beep Codes
The computer's way of telling you something is wrong, and an area to look into for it.
The beeps come out in a code
May be a long beep, then a pause followed by 2 short beeps.
May be 2 short beeps, a pause, then it beeps 2 short beeps, pause, and all over again.
You get the picture
Now in your best recollection just state the facts sir...............
What?
I mean what beep code so you hear Saltrock?
Post back in a Comment.
While I wait.............
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
(If you have the laptop hard wired to your router, unplug the cable from the laptop)
2) Laptop closed turn it over, Battery Compartment facing Away from you.
Remove the large panel on your side. Looks to be one single Philips head screw to remove/loosen.
Lift the Harddrive/Ram Memory Compartment Panel, up on the screw side at an ANGLE.
There are TABS on the panel on your side, that go into the Base Enclosure. (Bottom Cover)
Move the panel a little towards the Battery Compartment, and remove.
The Ram Memory module/s ('Stick') are held in by two spring clips on each side.
Closer inspection will reveal the spring clips have a protrusion, or 'Bump' on them.
These bumps fit into Side Notches, in the Ram Memory module.
Simply ease one spring clip to the outside. Be gentle.
The spring clip only needs to move far enough, for the 'bump' to clear the Side Notch.
Now do the same for the other spring clip.
When both spring clips are eased to the outside, the Ram Memory module will 'spring up' a little bit.
The BODY of the Ram Memory module, is everywhere on it, EXCEPT the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the BODY.
See the angle that the Ram Memory module popped up to?
Remove the Ram Memory module AT THAT ANGLE.
Reinstall the Ram Memory module at the same slight angle.
Failure to comply, can damage the gold plated contact pins on the Ram Memory module, and/or the contact pins in the Ram Memory slot.
When reinstalling insert at an angle, and fully inserted into Ram Memory slot. Then gently press down on the side that is tilted up; until the spring clip bumps pop into the Side Notches. (Of the Ram Memory module)
Note that there is a Locating Notch, on the Bottom of the Ram Memory module. (Where the gold plated contact pins are),
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Make sure you line the Locating Notch of the Ram Memory module, up with the Locating Lug in the Ram Memory slot.
The Ram Memory module only goes in ONE direction.
What I would like you to do, is remove all Ram Memory modules, and clean the gold plated contact pins.
Use a pencil eraser.
If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub back, and forth; and up and down. Clean EACH gold plated contact pin. BOTH sides. Doesn't take much pressure, nor rubbing to clean them.
Doesn't take much 'corrosion' to make a bad contact, either.
(Corrosion in marks because Gold isn't supposed to corrode.
Just my term)
When finished use air to remove the eraser dust.
If a can of compressed air for computers is available use it.
If not air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
Reinstall the large panel cover.
Reinstall the Battery.
Reconnect the AC adapter, and then plug it into power.
WAIT 1 minute, turn the laptop on.
Still no?
I await the BIOS Beep Code then.
Asus Support > Asus N56VJ series of Notebook PC > Downloads page,
http://support.asus.com/download.aspx?SLanguage=en&m=N56VJ&p=3&s=390&os=36&hashedid=2W6oktGQFZdwZ7cP
Scroll down. Click on the blue + sign, next to the blue Manual (4)
Scroll down to Version E6951
To the right of - Download from,
click on the Blue -> Global
This is a PDF file. It is also the User Guide.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Global it may take up to 30 seconds, before the first page comes up.
Go to Page 64 - Locating the hard disk drive
Shows you the panel to remove, and where the screw is located.
Page 66 - Memory (RAM) does not show you the panel, nor screw.
Regards,
joecoolvette
Feb 06, 2013 | Unknown ASUS N56VJ-WH71 15.6" Premium...
Asus N73SV-FHD-TZ087V
Your description is glare.Waht means funtion keys? Shorcut = right click WMP on the Start Menu and "sen to the desktop"
Apr 30, 2012 | ASUS N73JQ-A2 I7-740QM Notebook
ASUS EBXB202BKX0023 Eee Box - Black PC Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
