Question about Canon I-sensys MF4010 All-In-One Laser Printer
Canon MF4010 "Please wait" error
Asap i turn on the printer, it starts but on the screen i can see only "Please wait" and nothing more, no copy, no fax, no scanner. Could you help me please?
SOURCE: MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Posted on Sep 19, 2008
SOURCE: i can t send fax with my Canon MX300
plz sand mee fax pro
Posted on Dec 31, 2008
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
  • 78 Answers
SOURCE: I have a Canon Pixma MP780...it says it's offline
Unplugging the printer from power and letting it sit for at least 10 minutes should clear the error, unless there is something physically wrong with the printer.
Posted on Sep 29, 2010
puertobori
  • 7733 Answers
SOURCE: Error 6C10. Message tells me to consult the user
Try some of this fixes:
Posted on Oct 26, 2010
What is responsible for system error e225
have listing of most common codes here:
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
system error e225 refer to bad connection or power failure to the scanner, sometime can be solved, please follow this procedure:
1. switch machine on and wait till fully initialize, while it is "alive" disconnect power cord
2. leave disconnected for 10min
3. if possible - connect to known working different power socket (directly to the wall socket! no extensions, no power boards!)
4. wait till fully initialized, check if error still display, if not - problem solved,
if still error is displayed, go to canon site (this is not us unit, select therefore your appropriate division, somewhere there find contact and ask them for firmware update:
canada:
http://www.canon.ca/inetCA/en/serviceDetail?m=load&id=5&sid=28&mid=0002200586&type=S
australia:
https://www.canon.com.au/about-canon/contact
europe:
http://www.canon-europe.com/For_Home/Product_Finder/Multifunctionals/Laser/i-SENSYS_MF4380DN/
hope this will help you find correct solution, do not forget to vote...
Jan 12, 2015 | Canon I-sensys MF4010 All-In-One Laser...
Mf4010 scan error255
go here
http://www.copytechnet.com/forums/canon/41284-e255-black-lines-ir5000.html
Apr 28, 2014 | Canon Computers & Internet
How can i solve a system error e225 on a canon printer mf4010
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Nov 22, 2011 | Office Equipment & Supplies
How to install the canon mf4010 driver in the computer i have driver Cd but its not applicable
maybe CD is corrupted. try downloading the software from canon site im sure that will work
May 12, 2011 | Canon I-sensys MF4010 All-In-One Laser...
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 28, 2010 | Office Equipment & Supplies
ERROR E225
system error e225 on canon mf4010
Jun 04, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
May 29, 2010 | Office Equipment & Supplies
Canon I-sensys MF4010 All-In-One Laser Printer Logo
81 people viewed this question
old marine
old marine
