Question about Garden
Ryobi 990r starter rope replacement - Garden
  • 316 Answers
SOURCE: ryobi ry34000 Starter rope will not recoil
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you. gtui
Posted on Feb 19, 2012
panilling9
  • 284 Answers
SOURCE: ryobi 990r trimmer
alot of trimmers now have limiter caps on the carbruetors to keep the homeowner from making adjustments due to epa regulations and the ethanol fuel is 10% is not good either
So unless you have access to or a way to remove the caps for adjustments its a hard fix
you could remove the carb. and take apart to make sure the rubber pieces are still pliable.
the fuel will harden them over time and the carb will not deliver fuel to engine properly.
check you fuel lines to make sure they are not cracked or broken
Posted on May 26, 2009
  • 77 Answers
SOURCE: Ryobi 825R Weed trimmer. I need to replce the
Its a pain in the ****,even for someone that does it for a living,my advice is take it somewhere to have it done. Im not being a ****,Im just telling you there is a lot that can go wrong doing it yourself on a trimmer.
Posted on Aug 17, 2009
  • 109 Answers
SOURCE: just tried starting my ryobi trimmer and the
if ti didnt retract chances are the spring is broken and will need to be replaced
Posted on Aug 23, 2009
tbreeze47
  • 3083 Answers
SOURCE: Where can I get a throttle cable for a Ryobi 990r
This website has parts, diagrams, and should be able to help you out:
http://www.ereplacementparts.com/ryobi-990r-411088141-string-trimmer-parts-c-7931_15633_25094.html
Keep this site in your favorites, since it's one of the only sites that supplies these detailed diagrams and parts lists.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 24, 2010
How can I fix the starter cord on my ryobi back pack blower?
Rope has probably wedged somewhere. You will need to remove covers to get access to the rope pully and free it up. You may find that a new replacement rope is needed to correct the problem and prevent it's "catching" later. Now is a good time to replace with new.
May 12, 2015 | Ryobi Garden
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
Ryobi string trimmer RY34420 has a non retracting pull cord. How do I fix it?
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Aug 31, 2010 | Ryobi Garden
I have no spark on my ryobi 990r. i have replaced sparkplug. i have checked and have plenty of fuel
make sure the gap on the plug isnot to wide other wise u will not get any spark or just a weak spark
May 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I replaced start string and have no recoil of it on a Ryobi 30 cc
Watch the video, about 60 seconds in he explains how to tesion it.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Ryobi Factory Reconditioned 18" 40cc...
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi cs30 rope problem
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Mar 19, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
