Question about Baby Jogger City Select Stroller
Broken clip replacement
Is it possible to purchase a new clip for the harness?
    New Friend:
    Problem Solver:
  • 6 Answers
Buggy Pitstop has these clips in stock. Check them out on www.buggypitstop.co.uk
Posted on Aug 06, 2013
1994 Lincoln Town Car 4.6L V8 Is it possible to find the wires for the blend door actuator in the harness? I want to clip them, so I don't have to tear the dash apart.
You might get by with simply pulling fuse 8. See diagrams at link below. If that shuts off something you need, see if you can clip the black ground wire to the actuator.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=4938
Sep 21, 2017 | Lincoln Cars & Trucks
Broken contact clip
No you have to replace the hose.
Jan 27, 2014 | Broan-NuTone Vacuums
Disassembly nuvi
The clips are part of the connector and can not be purchased separately, however it is possible to remove a clip from another connector and install it on the connector with the missing clip. It takes a steady hand and there is a trick to get it on. We've done it many times in our repairs for our customers.
Jun 01, 2013 | Garmin nuvi 650 GPS Receiver
How to remove clip on shift lock on a 2006 Monte Carlo
I was having the exact same issue with my monte carlo ss just this week.
You obviously have taken it all apart so you can now see the harness. The release for the clip is situated in a difficult place.
There is a 1.5 inch thin strip of plastic that covers the shifter shaft. Slide this up and either use an elastic band or tape it to the shifter, just to hold it up and out of the way.
Now shine a flash light down and to the right and you will see the back of that stupid gray clip. Use a flat head or some thing similar to dislodge the clip.
Now you will have to remove the blue things on the clip and remove the old broken wire out of the harness. Make sure you document which colored wire goes where.
You will however have to attach new terminals to the ends of the wires before inserting them into the harness again. You can purchase these from any auto parts place. (I just grabbed some from my friend's shop.)
Jan 19, 2012 | 2006 Chevrolet Monte Carlo
Bugaboo frog.....one of the seat harness clip broken
If you contact www.bugaboo.com you will be able to purchase the replacement harness.
I hope this helps.
Nov 28, 2009 | Baby Gear
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
F9 error code while cleaning. What is broken?
HI, this is a lock switch mechanism failure.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wiring is connected properly, simply replace the door lock switch.
***(It is possible that is is stuck. trying correcting this before purchasing a new switch)---(Highly uncommon)
Jul 15, 2009 | GE JTP20 Electric Single Oven
Broken harness on bugaboo cameleon!
I actually called bugaboo and they are sending me a new clip. covered under my guarantee.
Jun 12, 2008 | Bugaboo Cameleon Jogger
Replacement parts
My manuel has an order form to send in to Dorel Juvenile Group Inc. There website is www.djgusa.com , you might be able to find it on there.
Sep 22, 2007 | Cosco Alpha Omega Elite - Hammer Print
Broken harness on bugaboo frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Jul 16, 2007 | Bugaboo Frog - Aubergine Stroller
Baby Jogger City Select Stroller Logo
69 people viewed this question
Top Baby Jogger Baby Gear Experts
Lyle Siemens
Lyle Siemens
john h
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
