Question about Toastmaster 3302 Iron
How to remove top
I have removed the front screw but the rear of the top is still attached and I can not find what is holding it.
How do IO remove the sole plate because a screw has come loose inside at the front making the sole loose
you have to access the iron from the top or from the heal. the base is solid and can not be accessed from the bottom look on the heal plate of screws then the top should lift foward.
I hope this was useful
May 01, 2014 | Russell Hobbs 15129 Slipstream Iron
Stirella sx 8040 d
We have removed the only screw we can get to but can't get the handle off to get to the inside screws
Apr 06, 2014 | Steam Fast Irons
I need to know how to take apart a Black & Decker Press 'n GO
Maybe a direct inquiry to Black & Decker will yield some useful information.
Feb 20, 2014 | Irons
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Morphy richards comfigrip 40715 how to disassemble?
Phil - I have the same problem. Can't see how to dismantle it at all. Did you ever get a solution?
Thanks
Chris
Aug 08, 2009 | Black & Decker AS975 Iron
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Singer Steam Press PRO9S
I have a Singer steam press Pro-9S, the top plate is loose from the screws holding the hot plate and the cover arm, I like to know how to remove the hot plate cover from the arm to tighten those screws. Thank you.
Feb 18, 2008 | Irons
Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Feb 17, 2008 | Irons
Toastmaster 3302 Iron Logo
26 people viewed this question
Top Toastmaster Irons Experts
Are you a Toastmaster Iron Expert? Answer questions, earn points and help others
