Xerox 7142 filtre waste fluid tank
How do i bleed air from the fuel tank/pipe. i ran out diesel, i have now put in 10 litres into the tank
Normally a small pump top of fuel filtre have to prime it and mihght have open little bleed screw on filtre
Nov 20, 2015 | Cars & Trucks
I have a Xerox 7142 wide format printer. It gives me this error on the machine. How do I fix error - E016 CPUErr [35]
Looks as if the series of E016 CPUErr point to a problem with the main board and may need to have a replacement, so would suggest a maintenance call out. Sorry.
Feb 26, 2015 | Xerox Office Equipment & Supplies
Mx366 waste tank is almost full
When my xerox says that I order a new waste tank and when it quits working install it. It sounds like you missed the replacement part.
May 17, 2017 | Canon Office Equipment & Supplies
Replace waste toner tank
it can be full the waste toner, or doesn.t fit after you unloading.
May 07, 2011 | Xerox Phaser 6110 All-In-One Laser...
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
It says that the waste tank is full. how do i empty it
you can remove it and CAREFULLY shake out the waste toner. You can do this 2 or 3 times (depending on how many pages you've done). Eventually the internal counter will not let you do it anymore, and you'll have to buy a new waste tank ($15-20).
Sep 30, 2009 | Xerox Phaser 6110 All-In-One Laser...
Message: waste cartridge is full or not installed
There is a possibility that the Imaging Unit needs replaced.
Or is the sensor itself unseated from its normal operating position.
Nov 20, 2007 | Xerox Phaser 6100/BD Laser Printer
99 people viewed this question
k24674
