Onida tv24"colourtv connected with rf converter video is there no sound
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If video is OK, sound should be there. Check its speaker first. If it is fond OK, check the connected cable for any break [in case of audio side]
Posted on Jul 24, 2013
I went s video out of dvd player into rf modulator video converter to rca cabels from modulator to tv and still doesnt work
It sounds like you have got the cables mixed up. You need to plug the output of the modulator into the aerial connection on the TV. The idea of an rf modulator is to let you connect a source into a TV via the antenna connection on the TV.
Mar 21, 2016 | RCA Televison & Video
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
Onida Audioport 21'' CTV no picture & sound
this is video section problum .pls check video mute trangester is sort.
or croma ic is filed
Oct 20, 2009 | Televison & Video
I have an old TV, which is now connected to the digital-analog converter box. How do I add a DVD player to this (it's so a not very mobile senior citizen can watch movies). Thanks very much!
You need an RF convertor (available most electronis stores -Walmart) Check instructions of RF converter purchased
Guideline:
The video audio cables (R,W,Y) should be connected to the matching colors on the RF converter and the RF cable (standard cable)should be connected from the RF conv. where it say "to TV" to the TV and the TV should be set to either Ch3 o Ch4 (you can usually choose on the RF conv.) the cable from the cable provider should be connected to where it says "in from antenna or cable in on the RF conv.
Oct 19, 2009 | Apex Digital AD-1165
I JUST BOUGHt a ps3. I am trying to connect it to my tv through a converter box. I have it all connected, but it does not play on my tv screen. What can I do to make it play?
What do you mean converter box? RF converter? The video audio cables (R,W,Y) should be connected to the matching colors on the RF converter and the RF cable (standard cable)should be connected from the RF conv. where it say "to TV" to the TV and the TV should be set to either Ch3 o Ch4 (you can usually choose on the RF conv.) the cable from the cable provider should be connected to where it says "in from antenna or cable in on the RF conv.
Oct 17, 2009 | Televison & Video
Can not make the instalation betwen my tv and my dvd player
Most DVD players today have only RCA jacks for video and audio outputs, and don't have RF (channel 3 or 4) outputs. If your TV doesn't have AV input jacks (either too old or just not supplied on your model) you can't connect the DVD player directly. You'll need to get an RF converter to make the connection.
An RF converter costs about $15 and you'll find them where you can buy TVs. The converter takes the video and audio signals from the DVD player and creates a channel 3 or 4 output signal to your TV. If you don't have the cables already, make sure to get them too. You need a "dubbing cable" (RCA plugs on the ends, usually color-coded red, white and yellow) to connect the DVD player to the converter input jacks and an RF cable with "F connectors" on the ends for the output to the TV. Often the dubbing cable comes with a new DVD player, and the RF cable with the RF converter.
If this takes care of your connection troubles, please take a moment to give my solution a good rating. If I've missed something and can be of more help, please post a followup comment.
Mar 31, 2009 | Symphonic ST4819 19" TV
No sound on TV
If you do not get result you can purchase one video rf converter. Rf converter contains one video input in yellow colour and two audio in red and white colour and one cable connector as outout. Connect dvd output to this converter and tune the program in which place you receive dvd signal.
Sep 16, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
