Question about Epson SX230 Multifunctional Inkjet Colour Printer EPSON
Sx 230 paper jam
Error w-02
    Top Expert:
  • 12,223 Answers
This kind of error is to due the paper jam. Take out and clean any residue of paper. And use the utility maintenance, and clean inside the printer and execute again.
If the problem persist, you must carefully with the humidity of paper, put some hot to the paper while you are working.
God bless you
Posted on Jul 24, 2013
Testimonial: "thanks let me try an see."
Canon Pixma MG 3200 is showing error code 02. I have reloaded the paper 20 times - no joy - stilll error code 02 - Any ideas?
remove jammed paper stuck inside the printer slowly, and u should be up to go
N.B do not pull the paper out forcibly from the front tray as this may cause serious damage
if u dont find any paper inside try to clean what ever it stuck inside the printer and be careful
Mar 22, 2017 | Canon Office Equipment & Supplies
E4 02 error code
Paper Jam Causes 1. Paper Jam in Fuser Unit. 2. Paper Exit Sensor clear and close the front cover
Jan 10, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
Epson sx438w e-02
did you check paper feed driver unit sensor in paper fixing fil or board
Feb 19, 2013 | Epson Stylus Sx438w
Error code H5-02
Paper jam in fuser unit or paper jam not removed for a certain period thus machine gives error.
could be cancelled using simulation 14.
Feb 22, 2011 | Sharp Office Equipment & Supplies
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
Service error 02
SE 02
: Software Exception
Jan 12, 2010 | OKI B6500 Led Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Epson SX230 Multifunctional Inkjet Colour Printer EPSON Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
