Question about Health & Beauty
Towbar removal how to remove - Health & Beauty
2 Suggested Answers
  • 33 Answers
SOURCE: I WANT TO FIT A TOWBAR TO MY 05 REG X TYPE ESTATE JAG
Yes you do need to remove the bumper, remove the 2 torxs screws in each wheelarch, 1 upper bolt and 1 lower bolts behind the wheelarch liner each side. two nuts inside car each side along upper edge, 4 nuts behind trim on rear edge, and 3 plastic plugs along lower edge. Hope this helps
Posted on Jul 21, 2009
2004 series 3 BMW 316i fitting a Towbar mainly how to remove rear valance
you shouldnt need to remove the rear valance to fit a towbar ,i would suggest you contact a authorised towbar fitting workshop as it is not permitted to fit a towbar yourself ,it has to be done by a company with the correct authorised dealership as the towbar has to be certified with a europeon certificate of homoglonation and a plaque .then vehicle has to be presented at the vehicle inspection station for conformity .Then the paperwork of the vehicle changed to show its fitted with a towing hitch and a fee paid for this service .alicantecoli_18.jpgalso the electrics have to be connected by a auto electrician as every annual vehicle inspection the electrics are tested as well where a towbar is fitted .
May 29, 2011 | BMW 318 Cars & Trucks
Jaguar 2005 X-type estate towbar electric connector.
The Jaguar doesn't have a towbar connector as such, there is a dedicated towbar wiring kit available, this plugs into the lamp connectors and has a towing module incorporated into the kit.It also has a small connector that plugs in to a spare connector in the loom for cutting off the parking sensors when you plug in your trailer. If you are in the UK then check on the NTTA website for a towvbar supplier that can either send one out or is local to you.
Oct 25, 2009 | 2003 Jaguar X-Type
General instructions for fitting a towbar to a 1994 renault clio
remove the rear bumper and the bar bolts to the back panel, some have a stay that bolts up forward. you might have to cut a slot in the bottom of the bumper to clear the towbar.
Oct 21, 2009 | 2000 Renault 181
How to fit a megan towbar 54 reg oasis
Firstly you need to know the make of the towbar, then you can download the fitting instructions from the towbar manufacturers website. As far as electrics are concerned, I would recommend NOT using the secondhand electrics that you have unless you have a dedicated plug-in wiring kit as the wires were probably cut and may now be too short to use and the sockets may not be in tiptop condition, It's well worth the small expense af replacing them. The actual wiring will depend on what year and model the car is.
Sep 17, 2009 | 2004 Renault 181
Cant find the towbar electrics plugs for x-type
I assume that the towbar didn't come with a proper wiring kit as, unfortunately there is not a specific connector for the towbar wiring on the x-type, the proper Vehicle Specific Kit plugs into the rear light. There is a power connector with three pins on the left and a grey reverse sensor cut out connector also on the left. but you will either need to use a Vehicle Specific Wiring kit (about £175) or use a bypass relay system.
Aug 30, 2009 | 2006 Jaguar X-Type
How to remove rear bumper on a isuzu trooper swb ? cheers
Bolted on to the chassis same bolts as the towbar so if a towdar is fitted then you will have to remove both.
Aug 27, 2009 | 1995 Isuzu Trooper
Can you put a towbar in front of the mustang
If it is automatic then would suggest no doing this. When towing with rear wheels trailing the driveshaft is still turning the tailshaft of transmission,< rear wheel drive > and without motor running the transmission doesn't circulate fluid to cool it off. if it is the only way to move it for you without a trailor then it's best to remove driveshaft and use a car dolly to tow. If it is standard then driveshaft is not does'nt have to be removed. Either way a dolly is what you need to tow it, < towbar won't work > and old school chain or strap can damage fron bumper shell.
Apr 26, 2009 | 1993 Ford Mustang
Jan 26, 2009 | 2007 Jaguar X-Type 3.0 Sedan
Health & Beauty Logo
67 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
