Question about Haier / EncoreR Front Load Super Capacity Electric Dryer
Haier encore dryer beeps and lights up but doesnt turn on
The cycle select works but it doesnt turn on. this dryer is less than 8 months old. is there something im missing?
3 Suggested Answers
SOURCE: Haier 12,000 portable unit. Red light comes on STOP appears
Drained tank then operated fine
Posted on Oct 08, 2009
  • 40 Answers
SOURCE: I have a encore haier model number rwt360bw washer that works until most of the water drains after the wash cycle, it will not start the rinse cycle, how do I fix it?
Is there still water in the machine after draining?
Are your clothes wetter than normally?
Have u drained the filter?
Posted on Oct 02, 2015
My spin cycle is not working
could be many things, motor, broken belt or drive gear, it is not easy to diagnose or fix if it's old get another, if not get a technician.
Jul 12, 2015 | Haier RWT150AW Top Load Agitator Encore...
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My haier encore dryer clicks and the lights comes on but it will not come on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | Dryers
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Im at a complete loss with my dryer. It runs but doesnt heat
Check the 230v very carefully You may be hooking it up even with new wire just like the old. You have to have across the line 230
not just 230. Sounds like you need to have an electrician to check
230 across the line at the wall.
Let me know.
Leo Ponder
imufo2@sbcglobal
Jul 22, 2010 | Whirlpool GEW9250 Electric Dryer
When I turn the cycle control knob it no longer makes a noise
heatman101
fg
May 30, 2010 | LG DLG7188 Gas Dryer
Haier / EncoreR Front Load Super Capacity Electric Dryer Logo
51 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
