Question about Sewing Machines
Threading Instructions for sunstar km740bl twin needled lockstitch please?
MakikiChris
  • 84 Answers
SOURCE: brother XR65 twin needle threading
hi roscoepc1.....The threading pattern is identical to single needle. The only changes are that you now are threading 2 spools of thread, one thread for each needle. The only change that I reccommend, but not neccessary, is that while threading through the tension dial, lay your threads between separate discs, and not together between the same pair of discs. Your tension dial contains either 3 or 4 discs.......please update your post if you have any further information or questions.....good luck my friend
Posted on Aug 05, 2007
SOURCE: needle threading
Well we have found out the problem but cannot fix it. The small metal hook that goes through the needle, is slightly bent to one side, and being such a small space in that area cannot really get to it to straighten it. How it got like that I cannot understand, with the metal so hard. So from now on will haves to thread by hand, such a pain.
Posted on Aug 19, 2008
SewTechWayne
  • 186 Answers
SOURCE: twin needle
Any universal twin needle should work, there is no attachment. Just don't set your stitch width too big if you are in zig-zag!
I hope this helps and good luck.
Posted on Feb 05, 2009
  • 161 Answers
SOURCE: threading instructions for the lockstitch 2000
worth having a look on you-tube
Posted on Sep 14, 2010
SOURCE: Singer 626 twin needle threading
happy sewing
Posted on Jul 12, 2012
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
How to thread with double needle
You'll need to use two separate spools of thread. Machines that take a twin needle will usually have separated thread guides and two separate tension disks. Just make sure the threads are not twisted when threading. Might be better to thread one all the way through and then thread the second.
How To Use Twin Needles
Be sure to check the width of your stitch when using a twin needle. Because the needles will be wider than a single needle, it is very easy to hit the needle plate if setting it too wide.
Jun 11, 2016 | Elna 1010
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
Can't seem to thread the machine properly so's I can use twin needle and pin tuck foot. Keeps de-activating the machine, so obviously not threading it properly, but can't understand the instruction book.
when you insert the twin needles, & add the 2nd spool of thread,, you just thread the machine the same way as with a single needle,,
that's what I do & it works just fine
Nov 04, 2010 | Brother InnovIs 4000D Computerized Sewing...
The needles I have are round shafted, ( no flat side ). Which way do I face the small recess where the eye is ? My machine was given to me. It's self oiling. What type of oil should I use? And where can...
hi there
concern needle attached if your machine lockstitch machine you are use DBx1 and easy to attach just keep in your main at any machine the small flat must be obosit saide from you threading the thread.at lockstitch machin small flat must be at ur right hand and the long at ur left hand .concern oil you can use juki defrex No.1 or light clear oil for industerial sewing machine.
Oct 28, 2010 | Juki DDL-8300
Brother XR65 twin needle threading
Aug 05, 2007 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
