Question about Measuring Tools & Sensors
Intek pro 65 ohv not turning over - Measuring Tools & Sensors
3 Suggested Answers
  • 50 Answers
SOURCE: i have a craftsman 18hp ohv intek lawnmower will
check the battery and all connections leading to the starter
Posted on Aug 16, 2009
consaka
  • 661 Answers
SOURCE: 18.5 HP OHV LT INTEK BERNING UP STARTER
If you have a good battery then the problem likely is the valve adjustment. I know it sounds crazy but if the valve lift is not set right it has too much compression. These engines have a compression release for when it is cranking to make the cranking easier. When the engine starts it goes off and runs normal. If you get that adjusted it will run like new. it is pretty cheap to have the shop do it too.
Posted on Jul 22, 2010
How to remove piston on B&S 20 hp 4067770139E1
push out threw the top first unbolt rod and if you need to ask its best left to a pro
Jun 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Jun 25, 2009 | Garden
Measuring Tools & Sensors Logo
59 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
