Question about Samsung Refrigerators
Electricity consumption
How many ampers it needs
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
What model Samsung refrigerator?
Posted on Jul 24, 2013
My new Beko fridge freezer isnt producing ice. Dispenses water though.
It seems low refrigerant issue kindly check it by compressor conusmi amperes and current consumption of power if its different then it need to refil the refrigerant.
Jul 15, 2016 | Beko Refrigerators
Why would my malber WD 1000 keep tripping the breaker during drying cycle
breaker tripping is caused by an overload ( amps x voltage = watts). If the breaker is- for example -10 amperes and the voltage is 120 volts it equals 1,200 watts of power consumption and if the device is pulling more than the 10 amps setting of the breaker then, it will tripp. Just check how many amps is used by the device and if it is hooked to an electrical outlet that has a lower amps rating than the device then, it will tripp. Look for another electrical outlet that will support the device amps usage and give it a try to find if it does not tripp. If it still does then you may need to take it to a rapair facility to verify if there is any short within the device
Sep 20, 2015 | Malber Washing Machines
Replace the plug on microwave/convection oven
You will need a heavy duty 3-wire power cord rated at a minimum of 15 Amperes and 20 would be my choice.
Microwave ovens can draw well over 10 Amperes alone and having an additional heating element will raise the current consumption further.
Hopefully the circuit being used has a circuit breaker rated at 20 amps too.
Voltage rating is less important and any you find will be OK at 120VAC and likely hundreds of volts more.
Also, inspect the receptacle too; if the plug shows signs of heat damage, this can be caused by a bad wall receptacle.
Look around the cover plate on the wall for any signs of discoloration.
This is a sure sign of potential internal damage and both must be replaced to prevent a fire.
Feb 10, 2015 | Microwave Ovens
How Can I Calculate the Power Consumption of the MA5600? Please tell me!
Power in Watt = Current (I) in Ampere X Volt (V)
Just multiply the current in ampere used by ur device by the voltage supply (either 220 or 110 volts)
May 30, 2014 | Ericsson T202g Gpon Sbu Voice, Data, And...
My monitor doesn't have an adapter. It says 12 vDC but I don't know the amperes or mA it requires, What do I do?
moz-screenshot-7.pngHi
The supply would be 12v DC 1000mA you can even go little more in amperes like 1500mA also not a problem.
DO RATE MY SOLUTION
Jun 30, 2011 | Daewoo F227B Monitor
I have a microwave and I am not sure of the wattage . The model # is JES738WJ02 And seriall # is DS991786u could you please help me find the answer to how many watts this product is. Thank you
Your microwave oven is 700 watts. Its printed on front of the owner's manual. If you no longer have an owner's manual, you can go to managemylife.com and download or print a copy for FREE. Just type in the model number you provided under the "Manuals" link. Your manual is listed in .pdf (Adobe) format. I hope this help you.
Feb 28, 2010 | Microwave Ovens
I lost the adapter so i need to noe what is the
The ampere is the SI unit of electric current. The ampere, in practice often shortened to amp, is an SI base unit, and is named after André-Marie Ampère, one of the main discoverers of electromagnetism.
In practical terms, the ampere is a measure of the amount of electric charge passing a point per unit time.
Jul 27, 2009 | Creative Labs Inspire 4400 Computer...
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Slow or fast charge
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Dec 11, 2006 | HP iPAQ RX3715 Pocket PC
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
