Question about HP LaserJet Office Equipment & Supplies
Bad flash burn power cycle on hp p2055d
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
sounds like a short across the mains input on the power supply/ or triacs shorted out on fuser driver pwb,
before replacing the power supply (needed) you may also want to replace the fuser unit assembly as a whole as the problem may well have originated from here. ( I would suggest at this point if your toner supply is low for this machine -that it is just as cheap to replace the machine as it is to replace the power supply fuser and toner
Jan 22, 2014 | HP LaserJet P2055d Printer
How can print power point slide in hp laserjet P2055d?
why i can't print power point slide in laserjet P2055d?
Feb 18, 2013 | HP LaserJet P2055d Printer
Hp laserjet printer p2055d print blank pages what is the problem?
Probably a bad ink cartridge. Remove the cartridge and clean the face of it with alcohol to remove dried or clotted ink.
Dave W.
Sep 14, 2012 | HP LaserJet P2055d Laser Printer
My hp laserjet P2055d printer donot turn on.
Most of the cases, power supply goes bad, open check the input fuse, if its open check primary section of the power section, replace defective components.. if power supply good replace formatter..
Sep 12, 2011 | HP LaserJet P2055d Printer
My printer prints out a blank page if im trying to print a pdf from adobe reader. its hp laserjet.
it sounds like your printer cannot translate the the graphics being sent from your computer.
It may be that one of your printer settings is not set correctly.
Or, it may be as simple a solution as updating your driver for your printer.
Try here for a driver for Laserjet P2055D:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3662055&taskId=135&prodTypeId=18972&prodSeriesId=3662052&lang=en&cc=us
If this is not your model, search for your specific model on this HP website.
Note there are also firmware upgrades for the P2055D printer.
Cheers,
Steve
Jun 23, 2010 | HP LaserJet P2055d Printer
52 scanner error hp p2055d
Power off printer, wait at least 30 seconds and power it on. Make sure that the printer is not on a surge protector. It should be plugged directly into a wall outlet. If this doesn't help, you are probably looking at a replacement laser/scanner assembly.
Apr 12, 2010 | HP LaserJet P2055d Printer
785 people viewed this question
Seeker5211
Seeker5211
