Question about Dome 4 CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH
Elro dvr 320
Hdd failure
My dvr worked fine for several months and then all of sudden it stopped recording Could it be that the hard drive just stopped recording because of failure?
the HDD is a common component to fail in a DVR.
The DVR Itself should actually tell you the status of the storage device if you navigate the menu.
I could probably assist you remotely to find out if you like?
Apr 14, 2016 | Drive Televison & Video
How do I find the serial number on an elro dvr 320
most small engines have a serial number stamped into the base of the crankcase on one half.
May 05, 2015 | Garden
I forgot my password how can i reset it.
hay ya m8 you will need some sort of firmware on the hdd most times for it to work if you can get to menu settings see if you can formatt the hdd and see if that works if not get back to me and ill see if i can find a link for the firmware for ya hope this works for ya
Jul 01, 2014 | Digital Peripheral Solutions Q-See...
Dvr 9104v
Provide more detail re: your problem.
May 10, 2014 | GE Security SDVR-4-320 4-Channel Color...
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
Does not record programes
Most likly there is a problem with the HDD on the DVR if that is what you have DCT look like DVR's but do not have a HDD; If this is a DVR you will need to call you're provider or the manufacture of the DVR and have them Trade out the DVR; Never open the DVR and try to replace the HDD you're self you will damnage the box byond repare;
Aug 27, 2011 | Televison & Video
Blue light not on / power failure to DirecTV+Plus (Silver Box) April 2010 Recording capacity was at 3% left / no longer power / fan is on and working Want to get recorded movies, tv shows, etc., from...
Well if you have another dvr thats the same,,take cover off and switch hdd/hard drives,,or take ot out of the dvr hook it as a second hdd to your cpu and retrive the movies,,goodluck
Nov 20, 2010 | Televison & Video
Pioneer DVR-320-S is dead.
Well if it is dead and the transformer is getting power then next step is the processor.  Which if it is dead, then I am sure all the internal components are as well.  My recommendation is have a professional give you and estimate and buy a UPS unit that will regulate the power to you important expensive units such as this.
Jan 06, 2009 | Pioneer DVR-320S DVD Recorder
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
Dome 4  CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH Logo
88 people viewed this question
Top Dome Home Security Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Dome Home Security Expert? Answer questions, earn points and help others
