Question about Honda Garden
Honda izy mower broken clutch cable - Honda Garden
    Master:
  • 969 Answers
Replace cable.
Posted on Jul 04, 2015
2 Suggested Answers
SOURCE: how do I replace the clutch cable on my honda self
I fixed the drive cable just yesterday. If the model is exactly hrx217hxa with the serial number between MAGA–1000001 and 139999 as mine is, it can be quite involved to replace the cable if this is the first time, because honda wants to replace the "control arm" as well. You can find a detailed instruction to replace the drive cable from the following link.
http://www.lawnsite.com/showthread.php?t=281234
The part number that you need to order is 06225-VH7-305, which comes with a very brief instruction on how to replace based on the service manual (not the user manual). The above link will guide you to how to replace the cable, but since the transmission end of the cable changed, you need to replace the "control arm" as well. This requires to disengage the drive "belt", which is the first challenge. Once you disengage it, it is relatively straight forward to replace the "control arm" if you have the right tools (1/8" pin punch and a challen lock plier which are described in the instruction that came with the cable kit).
Engaging the drive belt back on is the biggest challenge in the whole process, unless you have the right tool to handle the powerful spring that pulls the whole transmission to give friction to the drive belt. I spent two hours to try to engage the belt without the right tool (probably you need a "brake spring tool"), and I finally did it.
The rest of the assembly process is straight forward if you memorize what you did for disassembly. The above link can help you as well.
I took pictures of every step, and am going to post it somewhere soon, but if you want to replace it soon, please send me a message if you need help.
Posted on Nov 24, 2009
What is torque setting for honda izy blade
just tighten it as tight as you can lawn mower rotation will tighten it more
Jul 07, 2014 | Briggs & Stratton Briggs Stratton...
Honda izy Hello, The handlebar on my honda izy
If you never intend on loosening the handle bar to fold it u0p then go out and buy two nuts ( probably 1/4-20 or 12 mm) and tighten it all down with a wrench
Aug 16, 2013 | Garden
Honda IZY back fires and pulls the starter rope out of my hand
Two possibilities here, either the blade bolt is loose ( the blade is used as a flywheel so needs to be tight ) or the flywheel key has sheared knocking the ignition timing out.
Feb 25, 2013 | Garden
Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Jul 10, 2010 | Garden
Honda Izy will not start.
try fresh fuel
Apr 04, 2009 | Garden
CUTTING OUT
Try removing the carburetor bowl, pour out the gasoline and rinse with clear FRESH gasoline, not gasoline that has been sitting round...also dump gas tank and fill with fresh gas. A lot of trouble but a good chance will work.
Mar 17, 2009 | Garden
Garden Logo
328 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
