Question about Epson Expression Premium XP-600 Small-in-One Inkjet Printer
Epson expression xp 600 error code 0xEA when setting up
Can anybody help please?,after installing setup cartridges the printer starts to initialize,half way through it makes a horrible clunking noise(like the print head carriage has moved across at too fast a speed ,then show up on display 'printer error, ERROR CODE 0xEA', anybody have any ideas or had the same problem and found a solution?,thanks
    New Friend:
I had the same problem today. I opened the printer below the scan bed, where you install the ink cartridges and there was a piece of packaging material that got left in that while I unpacked. I removed that and the 0XEA error was gone. I was sure the problem was nothing to do with the cartridge installation as it was the initial setup of the printer and cartridge installation was the next step based on the user guide. I was getting this error on initialization after setting the region, date and time.
Posted on May 14, 2014
  • stephanie branton
    stephanie branton Dec 09, 2014
    yep this was my probelm, thank you for sharing!!
    New Friend:
I had this error on setup. I hadn't put the cartridges in properly. They click in two positions. They need to be horizontal not at an angle
Posted on Jan 11, 2014
  • Alice OBrien
    Alice OBrien May 30, 2014
    yep... i hadnt pushed the cartridges down to snap in properly..THNAKS ...saved me a lot of headache!
    New Friend:
I had this too, on my unit it seemed that the cartridge caddy had a problem sliding all the way to the left. It got stuck and then issued this error message. I solved it by manually sliding the caddy to the left side applying firm pressure( but not breaking it ). After that it was able to slide by itself and completed the setup without any error messages.
Posted on Mar 08, 2014
  • Mike
    Mike Aug 07, 2014
    Thank you! This worked for me! Tried everything else first. Just pushed it enough to go the rest of the way left, turned it back on, and all is well!
  • Epson Master
  • 419 Answers
Sounds like you have a faulty unit... Given that you're installing setup cartridges it's obviously a new unit so take it back and get a replacement.
Posted on Jul 31, 2013
  • Mohammad Safaei
    Mohammad Safaei Feb 14, 2014
    I HAVE THE SAME PROBLEM WITH XP-605 ANY HELP PLEASE
  • Gilbert Benn
    Gilbert Benn Mar 14, 2014
    I too have the same problem with Epson 605, with the dvd and cd printer option. All inks in firmly and pushed carriage gently over to left side. Clunking sound and printer stops with error msg, nothing you can do except switch off and try again. Still no joy, what to do ?
    Habit-Forming:
    New Friend:
  • 6 Answers
The main causes of Error 0xEA
  • Jammed Carriage caddy.
  • Cartridges are not inserted properly.
  • Installing and Configuring issue.
If you remove these all causes then you fix this error easily. OR For step by step guide, you can click Fix Epson Printer 0xEA Error within 5 Simple Steps
Posted on Sep 25, 2017
  • 3 Answers
I got this error when trying to complete step 2 of the printer setup which is setting the language to English. This is a brand new printer. It made kind of a grinding noise then the 0xEA error appears in the screen. To solve this, I opened the top of the printer as described in the Step 3 (installing the ink cartridges). There was a piece of blue tape holding the moving part to the right. Removed it and the problem no longer occurred.
Posted on Mar 04, 2016
    New Friend:
I noticed packing materials where printer cartridges are loaded. The error got resolved after removing those. Thanks for the hep!
Posted on Dec 21, 2015
TimHuntJr
  • 88 Answers
SOURCE: When I turn on my Epson DX8400 it says that I have
take a look at the back of your printer there should be a panell that comes off if you can take that pannel off look in there there is most likely paper stuck back there not allowing your printer to spool
Posted on Dec 09, 2009
SOURCE: epson r290 printer no printing now
how to install and R290 printer & print
Posted on Jun 13, 2009
  • 202 Answers
SOURCE: Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Posted on Aug 02, 2008
  • 28 Answers
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Posted on Apr 14, 2009
bhagyavichar
  • 414 Answers
SOURCE: Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Oct 31, 2009
How to Fix Epson Printer Error Code 0xea?
i think thats for a ink cartridge problem without knowing the printer model not easy to help
Mar 21, 2018 | Epson Office Equipment & Supplies
What does an Epson XP 600 error code OxE3 mean?
Check this previous thread....
http://www.fixya.com/support/t18998484-epson_expression_xp_600_error_code_0xea
Oct 19, 2016 | Epson Office Equipment & Supplies
What does 0xEA error indicate?
Do you know how to check ' what is printing'? If you do, please check and delete all unwanted list on the printing queue. Switch it off completely and disconnect all the cables leave it for a few minutes and reconnect the cables and switch on. It should work.
Nov 07, 2015 | Epson Expression Premium XP-610...
Error code 0xEA
Steps To Troubleshoot Epson Error Code 0xf4
Epson Error Code 0xf4 and other such critical issues can occur due to loosing of the CD driver which came with the printer, zero availability of ink in the printer, broken issues with the printer device, incapable to run the printer spooler service and not able to connect the printer in an accurate way. But a team of Epson Printer Support professionals has found various promising solutions to troubleshoot the Epson error code 0xf4
Also, it is well said that one can dramatically improve the speed of their Epson printer while addressing various issues just mentioned above. It is recommended to download the 'Epson Error Code 0xf4 Repair Tool' to efficiently make your printer work faster. Well this is an advanced optimization tool which has strong ability to repair all the problems that are slowing the performance of Epson printer.
Solutions to Troubleshoot Epson Error Code 0xf4
Solution1: Repair Tool
·First download the "Reimage Repair Tool" for fixing up Epson error issues from trusted links on this page.
·Save this file to the Desktop so that you can have an immediate access to the file easily.
Reimage Repair Tool Download Link can be make in use by simply right-clicking on the software and save it to the Desktop
Step2: Navigation mode
·After downloading, navigation is required to have an access to the file location by simply double-clicking on it as suggested by a team of Epson Printer Technical Support experts.
·This will further start the installation process.
·User Account Control will simply prompt you if you wish to run the program by asking you to click the "Yes" button to continue the process.
·At the initial launch of the program, it will simply display a welcome screen where users are asked to leave the checkbox as "un-ticked" to allow the repair tool to take a step ahead in starting the function as an automatic scan
·Click on the "Install" to start the installation procedure. Step3: Internet connection
·Reimage will now install on its own on the computer and the tool will automatically download all necessary updates needed provide that you have an Internet connection
Step 4: Preliminary scan
·The tool will automatically perform a preliminary scan of the machine to help determine the PC status
·Once the scan is done, then the Reimage tool will let you know about which areas of the PC are completely damaged and will prompt you to repair if necessary. Step5: Repair the PC
·After Reimage has finished it's task, you will be asked to restart the computer to complete the process.
For more knowledge about the Epson printer errors, call us at our Epson Printer Customer Support department to get your issues resolved right now!http://epson.printertechsupportnumbers.com/
Oct 09, 2015 | Epson WorkForce WF-7620 Wireless Color...
What's wrong with printer set up when printer says 'printer error Turn off power and on again. Error Code 0xEA!!
Dear
The error mean the carriage assembly is jammed.ensure there is no material, tapes, or anything else stucked inside and the cartridges are seated in properly. If reseating cartridges does not help, turn the printer off, take out the cartridges and inspect them carefully to see if any material is left over on the cartridges.
If no material is found, reseat the cartridges and check again. If you still receive the 0xea error then contact the retailer you purchased the printer from for a replacement.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Epson xp 600 won't print cyan new cartridge
i have put in new cartridges will not print help maureen
Mar 01, 2014 | Epson Expression Premium XP-600...
Error Code OxEA
if you want to setup the printer and you not do setup please contact us the For more help visit cbrtechsolutions
Feb 09, 2014 | Epson Expression Premium XP-600...
Epson Expression Premium XP-600 Small-in-One Inkjet Printer Logo
17,461 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
