Hello I need help with my Pioneer vxs-920 led keeps blinking but can't turn on what's the course and solution
    Genius:
  • Audio Player... Master
  • 1,054 Answers
Try holding the advanced surround and power buttons. If it turns on then turns off again, there is a problem in the amp.
Posted on Jul 24, 2013
  • 2 more comments
  • Godwin Bruce Jul 24, 2013
    If I may ask what causes this problem
  • Steve K Jul 24, 2013
    Usually caused by a bad speaker or the speaker wires touching. If the unit senses this, it will turn itself off to try and avoid damage to the amp. If it turns off too many times, then it will lock itself into protect mode and one of the front panel lights will blink as you described.
    Thank you
  • Godwin Bruce Jul 28, 2013
    I tried holding the advanced surround and the main power switch but still didn't work the mcacc led keeps blinking help
3 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: Where do I find the manual for the Pioneer
http://www.pioneerusa.com/pio/pe/vgn/images/portal/cit_11221/49515operating_instructions_VSX-D509S_20023151515575700.pdf
Here's your manual. Hope this helps
Posted on Jan 02, 2010
SOURCE: My pioneer receiver vxs-918v standby/on button is
With the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Also, check the back panel for any loose wires. If a speaker wire is touching the metal it can overload the unit.
Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Posted on Jan 24, 2010
Pioneer VSX830K FL OFF blinks display shows AMP OVERHEAT.
You need to determine what is overheating. For example if it uses a fan is that working? It it blocked with dust.
Operating the unit with the top cover off will quickly tell you which part is overheating. You can wait till it shuts down, then carefully, with it now unplugged, search for the hot parts. If you find only one overheating on it's own replace it.
Don't burn yourself!
May 18, 2017 | Pioneer Audio Players & Recorders
Hi, I have a Pioneer plasma 'pdp-50mxe20' and when I turn it on it after a few seconds it goes off and the red led start blinking 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Dec 28, 2014 | Pioneer Televison & Video
Cost price
remote control for what device?
Jul 09, 2012 | Pioneer Televison & Video
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
My pioneer receiver vxs-918v standby/on button is blinking and will not work. We were watching a movie last night and it just went off. It will not do anything except blink. The manual just says call a...
Dec 28, 2009 | Pioneer VSX-918V Receiver
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
141 people viewed this question
 Grubhead
Grubhead
