Question about Air Tools & Compressors
Powercraft spare parts
We're can I get the end pipe on my tyre inflator that fits on to the tyre for my power craft compressor. The bit on the end that connects to the tyre has broken
  • 10 Answers
SOURCE: Phil & Teds Sport
It sounds like one of a couple possible problems:
*Perhaps the tires have been overinflated previously and have edged out of the rim. In that case, the all the air will need to be let out of the tires, the edges of the tires edged back into the rim and then the tires inflated to slightly below the maximum pressure.
*You indicated that it was new, so the suggestion above may not apply. If you used the gauge at the garage that is connected to the air supply, it is likely not calibrated proper and the tires are, in fact, overinflated - in which case the first suggestion should be followed.
*If it's not one of the first two and the stroller is in fact new, then you should return it and ask for a replacement. There is a third possible problem . . .
*If the stroller has been stored in the heat, it's possible that tubes may have "stuck" to the tires internally and are placing pressure unevenly. You can tell if the tires have tubes by letting the air out and pressing on the valve stems. If they move in, which they probably will, then there are tubes. If you can remove the valves from within the stem and evacuate all the air, the tubes may adjust and you can reinstall the valves into the stems and air the tires up again.
Posted on Jul 19, 2008
  • 135 Answers
SOURCE: rear air shocks not inflating at startup
First thing to check is the switch located in the trunk. You can manually turn off the leveling system if you are going to jack up the car such as for changing a tire. Sometimes people accidentally bump the switch and it gets turned off. If this is not the case check the compressor pump under the hood and see if it has power coming to it. The compressor would be running constantly if you have an air leak. There is also a leveling switch that calls for the pump to come on and off to check out if the compressor is not opearating. If you are getting power to the air pump and it is not operating, the unit may need to be replaced.
Posted on Jul 04, 2009
  • 850 Answers
SOURCE: problem with a wobble from front end of my pan
check the wheel bearings then the rim for runout when its spun !
Cheers Rob
Posted on Aug 15, 2009
macnutz
  • 541 Answers
SOURCE: my bugaboo's not been used
Tyre will be loose on the rim when deflated the problem is Bugaboo don't put a lock nut on the valve stem so it can pop down into the wheel when you try to inflate it with that joke of a pump Bugaboo provide. Best option is to just pop down to your local bike shop. Next best is to go to your local gas station as the valve is the same size as a car valve. Squeeze the tire tightly at the valve stem pushing it out as far as you can so you can fit the air line. Bugaboo recommend 15 psi / 1 Bar this is way to soft and I always inflate to 30 psi / 2 Bar. Try somewhere between the two as it's a compromise between ease of pushing vs softness of ride.
Posted on May 19, 2011
SOURCE: pro rider scooter road king
The Problem was resolved by Pro Rider under warranty including 2 new front wheels. The scooter is now running better than ever!
Posted on Aug 27, 2011
How do i change tube on the wheel for my pride prusuit 36 sport? I have it removed and screws in the center of wheel out
Deflate the tyre completely by removing the tyre valve only then undo the nuts on the outer bolts take the two halves of the wheel apart remove the old inner tube noting carefully how the valve was placed through the wheel. Check the wheel interior and rims for rough or rusty patches, clean it up fit the new (empty) inner tube making sure that nothing is pinched reassemble the wheel halves together and be sure to fully tighten all nuts before fitting a new inner tube valve and you are ready to inflate the wheel. Do this in stages and gently bounce the wheel to settle the tube and rims then continue inflating continue a bit beyond the recommended tyre pressure and then release the air to the optimum pressure.
idea. If you have uniform wheels, consider buying a 5th wheel as a spare and fit it to the tow bar/ accessory attachment point behind your seat. I've done this on my venerable Pride Celebrity XL8.
Jul 14, 2016 | Pride Health & Beauty
Power pro Craft 15 million candle power rechargeable halogen spotlight HSLR15M need charger information.
I have a PowerCraft Pro hslr15m
the power adapter is DC15V 300mA
CENTER POSITIVE
does anyone have info on the bulb?
Sep 24, 2013 | Camping, Backpacking & Hiking
Fuel leak on powercraft 720 generator
The fuel hoses can leak if bent in an unreasonable fashion during installation or upon completion of installation.
Oct 04, 2012 | Office Equipment & Supplies
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
Jun 08, 2011 | kawasaki Motorcycles
Will I be able to generate 15amps in my honda cigarette lighter to power tyre air compressor which is rated to work at that?
depends on the fuse rating for that circuit-you should be able to find that information in your owners manual, but if you do not have one,m plugging in the compressor and running it will determine if it is rated to rund that load-the fuse will pop, or it won't. 15 amps is not a large draw, you did not list the year and model but most power ports are 20+ amp rated and older cars (with cigarette lighters) were 30 amp.
May 23, 2011 | Honda Accord Cars & Trucks
My bugaboo's not been used for a while and so the tyres are flat. i now need to use it again, but as there's no bond between tyre and wheel, i can't inflate it....help!!!
May 19, 2011 | Bugaboo Cameleon Jogger
2008 beetle dash light on with a aexclamation mark
hi from uk this light is the tyre pressure monitoring system it is telling you that one or more tyres pressures are under inflation so! if you have not checked them weekly ? for your own safety you should may i suggest you check and inflate to correct pressure of all tyres inc spare ! obviously if one tyre is very low ? keep an eye on it? in case it has a slow leak/puncture ? ps the horse shoe is a low pressure tyre symbol ? best wishes from uk and merry xmas !
Dec 25, 2009 | 2008 Volkswagen Beetle
Hi, I am having great problems getting the bead of the tyre onto the bead grove on the rim. The majority of the tyre goes on ok but a small section on each side won't go on which causes the tyre not to be...
Using a technique for setting the bead on tubeless tires, i have had a little success, but some wheels are a real pain to set beads on. Anyway, the technique is to get the tube into the tire (which is ready to be seated) and inflate it just a little bit. Don't screw the collar nut onto the valve stem but leave it off for now. Now pinch together the beads of the tire and get them to sink under the tube and into the groove that runs in the middle of the rim. When the beads are down in there, then pump away and seriously go after it; the faster you can get air in there the better. Over inflate, but not more than you feel comfortable with: i have gone as far as 20psi over recommended pressure. The last ditch effort, if all else fails, is rolling the bead into place manually with your thumbs and some elbow grease.
Regards,
matt
Sep 13, 2009 | Cycling
REMOVING THE SPARE WHEEL ON A RENAULT MEGAN
The spare wheel is located under the rear boot carpet.BUT some meganes do not come with a spare as its an optional extra when the car is purchased. If there is no spare, then a can of foam and a small compressor to repair and inflate the punctured tyre, should be fitted.
TL
Oct 10, 2008 | 2002 Renault Sportwagon
Air Tools & Compressors Logo
50 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
