Question about Lexmark X654de MFP All-In-One Laser Printer
Reset i refill my lexmark x654de it says invalid toner how to reset chip
SOURCE: lexmark z1300 ink jet cartridge refill instructions
In order to refill the black ink cartridge on a Lexmark 1300 you need to purchase a 28a (18c1528)
cartridge. The 28 black ink cartridge is a return program cartridge and it won't let you refill it.
I found one at a site called computer friends for around $21.00. You can also google lexmark 28a ink
cartridge you can find them. I hope this helps. I've been frustrated with this problem also
Posted on Oct 15, 2008
mstipps
  • 16 Answers
SOURCE: refill on lexmark x3650
Not positive, but I read in a forum recently that this will NOT work with this cartridge.....if u find out, let me know. I need ink too....:(
Posted on Jul 07, 2009
  • 15 Answers
SOURCE: lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Posted on Jul 13, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark optra t610 invalid refill error change
    The error may not be specifically a toner cartridge problem but may be due to a stuck cover open switch on the printer. Perhaps this article on Error: "Invalid Toner Cartridge" or "Invalid Refill" will be able to determine the root cause of the problem. Just click on this link: http://bit.ly/dupj2m. Just make sure you are using a genuine Lexmark toner in the printer. If you need further assistance, you can also contact Lexmark technical support. Thanks.
    Posted on Sep 14, 2010
    • 544 Answers
    SOURCE: Lexmark Pro 705 won't let me print after refilled
    If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
    Posted on Oct 18, 2010
    What to do with 30.05 change "cartridge invalid refill" problem
    Buy Original Lexmark Tonor.
    If you refill tonor, you need a new "Tonor reset chip" - some tonor remaufacture will stock them. Cost less than $2
    Aug 08, 2014 | Lexmark Laser Printers 34S0400 E 360D...
    How to reset lexmark e260 chip
    Go to any website that sells bulk ink and toner refills. They have chip resetters. You need to do this every time you refill . It cannot be bypassed.
    Jan 24, 2014 | Lexmark E260 Laser Printer
    Cartridges error on a lexmark
    Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
    Solution
    One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
    To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
    If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
    Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
    Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
    Turn the printer off. Doing this will disengage the cover open sensor.
    With the printer switched off, open the top lid and remove the old toner cartridge.
    Now replace the old cartridge with another new Lexmark toner cartridge.
    Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
    If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
    If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
    To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
    If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
    OR
    1 Switch on the Lexmark X83 printer.
    2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
    3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
    4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
    5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
    6 Repeat each step in this procedure again. Close the cartridge door.
    Oct 04, 2012 | Office Equipment & Supplies
    Replaced toner by new, but error "Invalid
    You probably got a remanufactured cartridge (refilled) and the chip was not reseted properly. Take it back to seller for a replacement.
    Nov 30, 2010 | Samsung SCX 4200 All-In-One Laser Printer
    I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
    I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
    Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
    Lexmark optra t610 invalid refill error change cartridge......how do i reset the printer to disable the error
    Sep 14, 2010 | Lexmark Optra T614 Laser Printer
    Refilled a Lexmark c910 black toner cartridge. Still reads low or empty. Any way to override chip signal to printer so it still prints.
    Yes you understand, it is problem Toner chip.When finished your toner then it chip has been disable.It is a technical policy.If you can refill it and again use.You must be reset the chip.Help www.chip resetter.com
    Dec 06, 2009 | Lexmark C910 Printer
    CLP 300 toner cartridges invalid toner
    the drum has chips encoded,need cartridges with chips.
    May 29, 2009 | Samsung CLP 300 Laser Printer
    Lexmark error: 33.64
    Change Toner cartridge.
    Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
    Maxi
    Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
    Lexmark X654de MFP All-In-One Laser Printer Logo
    61 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
