Find smps problem solution
Smps sort in working and mather board conneted no power supply
    Top Expert:
  • 12,223 Answers
You have 2 options a) repair + b) replace by new ones.
God bless you
Posted on Jul 25, 2013
The top quarter of my philips lcd screen is fine but the rest is sort ov blured hazed, a bit like if the screen got water damaged.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 11, 2016 | Philips Televison & Video
Hi,I've got a Samsung 46 inch led TV and the right half is darker than the right,is this able to be sorted.
Aug 13, 2016 | Samsung Televison & Video
Black screen no sound no picture or color of any
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 16, 2014 | Televison & Video
Dell ps5022 2df how to test
remove smps and attach power chord to smps and sort green and black colored wire if fan works den smps is all rite if not den its faulty if smps is working den problem is with ur mother board
Jul 31, 2014 | Dell Computers & Internet
Ive had this bluray player for 2 years and it was working fine, then one day i tried to turn it on and nothing happened. i checked if the fuse was blown but i appears to be fine. so there is no power...
hi,
there is possibility of two complaints.
1, The SMPS power supply fault
2. the mother board fault.
if the SMPS is faulty the you can rectify the problem. If it is with the mother board the you have to contact the manufacturer .
First of all you have to check the SMPS ( switch mode power supply). you have to check the voltages at it secondary stage. 5v, 12v, etc
switched-mode power supply (switching-mode power supply, SMPS, or simply switcher) is an electronic power supply that incorporates a switching regulator in order to be highly efficient in the conversion of electrical power. Like other types of power supplies, an SMPS transfers power from a source like the electrical power grid to a load (e.g., a personal computer) while converting voltage and current characteristics. An SMPS is usually employed to efficiently provide a regulated output voltage, typically at a level different from the input voltage
for checkin the SMPS voltaes you need a multimeter. And check the voltages at it secondary stage
Added the inside view of BD 1600
if there is no outputs from the smps then you have to replace the SMPS drive STR ic near the big capacitor. Also ty to replace the OPTO coupler ic. y have to check the all resistors near the ic.
Remember one important thing that the capacitor can hold charge for some time even if you disconnect the power. so after removing the power. remove the SMPS very carefully. discharged the capacitor using a bulb.
i have also added a video for SMPS working for you reference will hep you for repairing your one
ok
Apr 07, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Power supply not working
DETATCH SMPS FROM MOTHER BOARD SORT GREEN & BLACK WIRE WITH A PIN AND SEE WHETHER SMPS FAN IS WORKING. IF NOT WORKING KINDLY ARRANGE TO REPLACE THE SMPS.
Jun 22, 2010 | Dell Dimension 8300 PC Desktop
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
No power
There is no reset on this TV. The SMPS (switch mode power supply) has been a problem on some of these models. There are no components available for this board as it has to be replaced as an entire assembly. If one or more of the fuses on the SMPS board have opened up then you might have a bad scan or sustain board. A qualified technician will be able to diagnose which board is loading the power supply if this is the case. Good luck to you. Joe Weibel customelectronics.org
Feb 23, 2007 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
